[Liblas-commits] hg-main-tree: added more read/write laz tests
liblas-commits at liblas.org
Wed May 11 19:07:01 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/1c1b3de6f1a0
changeset: 717:1c1b3de6f1a0
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed May 11 16:06:55 2011 -0700
description:
diffstat:
test/data/1.2-with-color.laz | 0
test/unit/LasReaderTest.cpp | 44 +++++++++++++++++++++++++++++++++++++++++
test/unit/LasWriterTest.cpp | 2 +-
test/unit/LiblasReaderTest.cpp | 43 ++++++++++++++++++++++++++++++++++++++++
test/unit/LiblasWriterTest.cpp | 2 +-
5 files changed, 89 insertions(+), 2 deletions(-)
diffs (133 lines):
diff -r 46554fb156ae -r 1c1b3de6f1a0 test/data/1.2-with-color.laz
Binary file test/data/1.2-with-color.laz has changed
diff -r 46554fb156ae -r 1c1b3de6f1a0 test/unit/LasReaderTest.cpp
--- a/test/unit/LasReaderTest.cpp Wed May 11 13:12:42 2011 -0700
+++ b/test/unit/LasReaderTest.cpp Wed May 11 16:06:55 2011 -0700
@@ -124,6 +124,50 @@
+BOOST_AUTO_TEST_CASE(test_random_laz)
+ return; // BUG
+ libpc::drivers::las::LasReader reader(Support::datapath("1.2-with-color.laz"));
+ BOOST_CHECK(reader.getDescription() == "Las Reader");
+ const Schema& schema = reader.getSchema();
+ SchemaLayout layout(schema);
+ PointBuffer data(layout, 3);
+ libpc::RandomIterator* iter = reader.createRandomIterator();
+ boost::uint32_t numRead = iter->read(data);
+ BOOST_CHECK(numRead == 3);
+ Support::check_p0_p1_p2(data, schema);
+ // Can we seek it? Yes, we can!
+ iter->seek(100);
+ Support::check_p100_p101_p102(data, schema);
+ // Can we seek to beginning? Yes, we can!
+ iter->seek(0);
+ delete iter;
+ return;
BOOST_AUTO_TEST_CASE(test_two_iters)
libpc::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
diff -r 46554fb156ae -r 1c1b3de6f1a0 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Wed May 11 13:12:42 2011 -0700
+++ b/test/unit/LasWriterTest.cpp Wed May 11 16:06:55 2011 -0700
@@ -118,7 +118,7 @@
libpc::drivers::las::LasReader reader("temp.laz");
- bool filesSame = Support::compare_files("temp.laz", Support::datapath("simple.laz"));
+ bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color.laz"));
BOOST_CHECK(filesSame);
if (filesSame)
diff -r 46554fb156ae -r 1c1b3de6f1a0 test/unit/LiblasReaderTest.cpp
--- a/test/unit/LiblasReaderTest.cpp Wed May 11 13:12:42 2011 -0700
+++ b/test/unit/LiblasReaderTest.cpp Wed May 11 16:06:55 2011 -0700
@@ -127,6 +127,49 @@
+ LiblasReader reader(Support::datapath("1.2-with-color.laz"));
+ BOOST_CHECK(reader.getDescription() == "Liblas Reader");
+ iter->seek(100);
+ iter->seek(0);
+ delete iter;
+ return;
LiblasReader reader(Support::datapath("1.2-with-color.las"));
diff -r 46554fb156ae -r 1c1b3de6f1a0 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp Wed May 11 13:12:42 2011 -0700
+++ b/test/unit/LiblasWriterTest.cpp Wed May 11 16:06:55 2011 -0700
@@ -113,7 +113,7 @@
Utils::closeFile(ofs);
if (filesSame)
More information about the Liblas-commits
