[Liblas-commits] laszip: quitting random seek loop after 100 seeks
liblas-commits at liblas.org
Wed May 11 19:36:40 EDT 2011
details: http://hg.liblas.orglaszip/rev/22d8d441f1a6
changeset: 234:22d8d441f1a6
user: isenburg
date: Wed May 11 16:34:07 2011 -0700
description:
Subject: laszip: merge
details: http://hg.liblas.orglaszip/rev/484b68b9d852
changeset: 235:484b68b9d852
user: isenburg
date: Wed May 11 16:38:59 2011 -0700
description:
merge
diffstat:
tools/laszippertest.cpp | 505 ++++++++++++++++++++++++-----------------------
1 files changed, 255 insertions(+), 250 deletions(-)
diffs (truncated from 599 to 300 lines):
diff -r 8bd0e8d832dc -r 484b68b9d852 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Tue May 10 07:35:16 2011 -0700
+++ b/tools/laszippertest.cpp Wed May 11 16:38:59 2011 -0700
@@ -157,7 +157,7 @@
bool m_use_iostream;
- const char* m_filename;
+ const char* m_filename;
FILE* ifile;
filebuf ifb;
#ifdef LZ_WIN32_VC6
@@ -175,37 +175,37 @@
public:
PointData(unsigned char type=5, unsigned short size=70)
- point_type = type;
- point_size = size;
- point = 0;
- point_data = 0;
+ point_type = type;
+ point_size = size;
+ point = 0;
+ point_data = 0;
- bool PointData::setup(unsigned int num_items, const LASitem* items)
- unsigned int offset = 0;
- if (point) delete [] point;
- point = new unsigned char*[num_items];
- if (point_data) delete [] point_data;
- point_data = new unsigned char[point_size];
- for (unsigned int i = 0; i < num_items; i++)
- point[i] = &(point_data[offset]);
- offset += items[i].size;
- return (offset == point_size);
+ bool setup(unsigned int num_items, const LASitem* items)
+ unsigned int offset = 0;
+ if (point) delete [] point;
+ point = new unsigned char*[num_items];
+ if (point_data) delete [] point_data;
+ point_data = new unsigned char[point_size];
+ for (unsigned int i = 0; i < num_items; i++)
+ point[i] = &(point_data[offset]);
+ offset += items[i].size;
+ return (offset == point_size);
~PointData()
- unsigned char point_type;
+ unsigned char point_type;
unsigned short point_size;
unsigned char** point;
- unsigned char* point_data;
+ unsigned char* point_data;
@@ -268,16 +268,16 @@
log("ERROR: could not make laszipper\n");
exit(1);
- int stat = 0;
- if (ost->m_use_iostream)
- stat = zipper->open(*ost->streamo, laszip);
- else
- stat = zipper->open(ost->ofile, laszip);
- if (stat != 0)
- log("ERROR: could not open laszipper with %s\n", ost->m_filename);
- exit(1);
+ int stat = 0;
+ if (ost->m_use_iostream)
+ stat = zipper->open(*ost->streamo, laszip);
+ else
+ stat = zipper->open(ost->ofile, laszip);
+ if (stat != 0)
+ log("ERROR: could not open laszipper with %s\n", ost->m_filename);
+ exit(1);
return zipper;
@@ -291,16 +291,16 @@
log("ERROR: could not make lasunzipper\n");
exit(1);
- int stat = 0;
- if (ist->m_use_iostream)
- stat = unzipper->open(*ist->streami, laszip);
- else
- stat = unzipper->open(ist->ifile, laszip);
- if (stat != 0)
- log("ERROR: could not open laszipper with %s\n", ist->m_filename);
- exit(1);
+ int stat = 0;
+ if (ist->m_use_iostream)
+ stat = unzipper->open(*ist->streami, laszip);
+ else
+ stat = unzipper->open(ist->ifile, laszip);
+ if (stat != 0)
+ log("ERROR: could not open laszipper with %s\n", ist->m_filename);
+ exit(1);
return unzipper;
@@ -378,7 +378,7 @@
srand(settings->seed);
c = rand() % 256;
for (i = 0; i < settings->num_points; i++)
unzipper->read(data.point);
for (j = 0; j < data.point_size; j++)
@@ -419,7 +419,7 @@
if (num_errors)
- log("ERROR: with lasunzipper %d\n", num_errors);
+ log("ERROR: with lasunzipper %d\n", num_errors);
getc(stdin);
else
@@ -433,215 +433,220 @@
-static void write_points_seek(LASzipper* zipper, PointData& data)
- if (zipper==NULL)
- return;
- double start_time, end_time;
- unsigned char c;
- unsigned int i,j;
- unsigned int num_bytes;
- start_time = taketime();
- // the two branches of this IF are the same, except for the use of a random number;
- // we keep the random case separate, so that we can get fastest timing tests w/o random data
- if (settings->use_random)
- for (i = 0; i < settings->num_points; i++)
- srand(i);
- c = rand() % 256;
- for (j = 0; j < data.point_size; j++)
- data.point_data[j] = c;
- c = rand() % 256;
- zipper->write(data.point);
- num_bytes = zipper->close();
- else
- c = (unsigned char)i;
- c++;
- end_time = taketime();
- log("laszipper wrote %u bytes in %g seconds\n", num_bytes, end_time-start_time);
- return;
-static void read_points_seek(LASunzipper* unzipper, PointData& data)
- if (unzipper==NULL)
- return;
- unsigned char c;
- unsigned int i,j;
- unsigned int num_errors, num_bytes;
- num_errors = 0;
- if (i%1000 == 0)
- int s = (rand()*rand())%settings->num_points;
- fprintf(stderr, "at position %d seeking to %d\n", i, s);
- unzipper->seek(s);
- i = s;
- unzipper->read(data.point);
- srand(i);
- c = rand() % 256;
- if (data.point_data[j] != c)
- log("%d %d %d != %d\n", i, j, data.point_data[j], c);
- num_errors++;
- if (num_errors > 20) break;
- c = rand() % 256;
- num_bytes = unzipper->close();
- else
- if (i%1000 == 0)
- i = s;
- num_errors++;
- c++;
- if (num_errors)
- getc(stdin);
- else
- log("SUCCESS: lasunzipper read %u bytes in %g seconds\n", num_bytes, end_time-start_time);
- return;
+static void write_points_seek(LASzipper* zipper, PointData& data)
+ if (zipper==NULL)
+ return;
+ double start_time, end_time;
+ unsigned char c;
+ unsigned int i,j;
+ unsigned int num_bytes;
More information about the Liblas-commits
