[Liblas-devel] .net/mono bindings in c#
Martin Rodriguez
mrodriguez at stereocarto.com
Fri Aug 8 03:57:35 EDT 2008
Hi>
> Hi>
>> I saw a Trac login on http://liblas.org under the name 'martin' and I
>> assumed that is you. Anyway, I have given you svn commit access, and
>> I created a csharp directory in which you can layout and place your
>> bindings. I would suggest hanging out on #liblas on irc.freenode.net
>> to catch Mateusz and I if you have any questions.
> Yes, i am. Thank you
> csharp directory not please. This is not a c# bindings else mono/.net
> bindings.
> For GDAL and MapServer, we use csharp as the catch all name for
> the .net families of languages. This is mostly because calling the
> directory ".NET" or anything similar is likely to cause problems
> (hidden directory on *nix using the literal .NET directory name --
> calling a directory "net" is not very descriptive).
I know. I am using that bindings right now to insert geotiff images in
autocad, hehe.
>I wouldn't be adverse to renaming the directory to "dotnet" if you
>wish, however...
mono or dotnet sound great. I want create samples in c#, boo, visual Basic
and so.
In mi library I create a namespace called MONOLAS, but I am going to change
it to LibLAS namespace. Then the name is for the DLL monoliblas.dll or
dotnetliblas.dll like gdal bindings.
For me use dotnet because many people hate mono project, and we have also
dotgnu project.
Regards.
More information about the Liblas-devel
