[Liblas-devel] RE: Building the .net/mono bindings
Mateusz Loskot
mateusz at loskot.net
Fri Aug 29 11:07:34 EDT 2008
Martin Rodriguez wrote:
> Yesterday i was trying learn autotools for mono. Is it enough compile only
> my library or the autotools have to create NUNIT tests and compile samples
> also?.
Building library is a minimum, but you may want to build & run tests as
well.
> I want use your las files to NUNIT, so I hope be informed about changes in
> this files.
Sure.
> Is it possible add NUNIT DLLs to the csharp trunk?
Is it needed?
Why not to ask user to install NUNIT in his environment?
Plus, make ./configure to detect availability of NUNIT and turn on/off
execution of tests - automation is the key.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
