[Liblas-devel] Writing Scan Angle Rank values
Mateusz Loskot
mateusz at loskot.net
Thu May 1 21:58:26 EDT 2008
Howard Butler wrote:
> The specification says the following for Scan Angle:
> Scan Angle Rank (-90 to +90) – Left side unsigned char 1 byte *
Hobu,
Where do you see "unsigned char"?
I've rechecked LAS 1.0 and 1.1 and in both versions use "char" (signed
char). The data member description confirms:
"The scan angle rank is a signed one-byte value"
So, I believe we are OK.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel
