GRASS LiDAR tools [it was Re: [Liblas-devel] Hello!]
Roberto Antolín
rantolin at stereocarto.com
Thu May 8 04:44:52 EDT 2008
Hi Howard and all,
Howard Butler wrote:
> Roberto,
> Did you have to write LAS reading/writing software as part of your
> effort, or did you dump the LiDAR data to text before consuming the data
> with GRASS and beginning your processing?
This is exactly how it works: making an intermediate ascii file before
importing it into grass. To be honest, I "didn't care" about LAS format
since all the data I was supply with was in text format.
Besides, old grass versions (more than four years ago) permitted to work
with "site_lists" [1], that is text files, which made grass a perfect
software for lidar data management. Unfortunately, it was impossible
with new version, where only binary grass vector and raster are allowed.
Still, it is possible to import lots of vector and rasters formats. In
fact, when we thought to update the old lidar commands, we decided to
use the builtin r.in.xyz and v.in.ascii modules in order to import lidar
data as text.
I've took a look into the Mateusz's thread in the grass-devel list and I
agree that, by the moment and as a fast thing, it would be possible to
make a wrapper with last2txt and v.in.ascii or r.in.xyz. Later, it would
be great to make a *.in.las command or something like that. I don't know
whether it is possible/necessary/useful to embed libLAS to work directly
with the grass lidar tools (v.lidar.*).
[1] easting|northing|[z|[d4|]...][#category_int] [@attr_text OR %flt]
Regards,
Roberto.
Roberto Antolín Sánchez
Departamento de Tecnología
Stereocarto S.L.
Paseo de la Habana 200
28036 - MADRID, Spain
Telf: +34 91 343 19 40 - FAX: +34 91 343 19 41
http://www.stereocarto.com
More information about the Liblas-devel
