[Liblas-devel] Support for Variable Length Records
Martin (OpenGeoMap) martin at opengeomap.org
Sat May 17 12:27:19 EDT 2008
Howard Butler wrote:
> All,
> Building on some work by Mateusz, I have added support for VLRs to
> libLAS.  The most useful application of this support is the reading
> and writing of georeferencing information for LAS files, but it also
> allows us to carry forward VLRs as part of a LiDAR processing chain
> that includes programs like las2las.  The VLRs are carried around as
> part of the LASHeader, and you interact with them as if they are
> another header data member.
> Frank Warmerdam helped us out with parsing and reading the
> georeferencing information, and there is now a LASHeader::GetProj4
> method that you can use to return the spatial reference of a LAS file
> that has VLRs describing the georeferencing information (actually,
> we've found very few of these files even though the spec says that all
> LAS files should have spatial referencing in the form of geotiff
> keys).  To utilize GetProj4, you must link a cvs head version of
> libgeotiff to libLAS with the --with-geotiff configure-time switch.
> Because we also support linking with GDAL, I plan to implement a
> GetWKT() (or similarly named) method to the LASHeader that will
> support ESRI SRS WKT operations.
> I think we should do a 0.9.7 release to provide the VLR and
> georeferencing work for people to test.  We need some good testing of
> this development with a wide variety of LAS files because the changes
> were a bit disruptive.
Where can we put las files?
perhaps a private FTP account. by mail it's something like difficult,
don't you think?
> Howard
> Liblas-devel mailing list
> Liblas-devel at mail.hobu.net
> http://mail.hobu.net/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
