[Liblas-devel] Changeset 1237
Howard Butler hobu.inc at gmail.com
Mon Apr 20 13:04:30 EDT 2009
On Apr 20, 2009, at 10:17 AM, Mateusz Loskot wrote:
> Hobu,
> "LIBGEOTIFF_VERSION is never defined by any of our configuration
> stuff.
> What was the thought here?"
> I know LIBGEOTIFF_VERSION is never defined anywhere in libLAS,
> but it is defined by libgeotiff.
> Now, if you build libLAS with GDAL (which includes libgeotiff in
> number
> of places), but *without* libgeotiff explicitly, libLAS does not
> compile. This is because:
I would note that the only supported configuration of using GDAL
*without* an explicit libgeotiff requires a *GDAL source tree*, and
not just the gdal-config script.  This is because GDAL does not
install libgeotiff headers as part of its install.  I don't think that
is the problem in this instance, however.
> 1. This is true
> #ifndef HAVE_LIBGEOTIFF
> 2. GDAL implicitly injects libgeotiff stuff into libLAS space, like
> typedef struct GTIFS *GTIF;
> So, we need to have extra test that assures
> is true only if both conditions are true: 1) libLAS is explicitly
> configured with libgeotiff and 2) geotiff header is included.
ok, I understand now.  reverted http://liblas.org/changeset/1241
More information about the Liblas-devel mailing list
