[Liblas-devel] Indexing for point clouds
Volker Wichmann wichmann at laserdata.at
Thu Apr 23 03:43:52 EDT 2009
Howard Butler wrote:
> <snip>
> On Apr 22, 2009, at 4:45 AM, Volker Wichmann wrote:
>> I've no experience with either spatialindex nor GML LidarK, but maybe
>> you can find some hints on
>> http://research.graphicon.ru/3d-point-data-processing/gml-lidark-library-6.html
>> There's some discussion on pro/cons of various indexing approaches.
> An excellent lead, thanks.  Do you happen to know if it is compatible
> with libLAS' license?
I don't think so, I just downloaded the zip and the license.txt says:
LICENSING TERMS
MSU Graphics & Media Lab, Computer Vision Group software is granted free
of charge for non-commercial use. However you must obtain a license from
the author to use it for commercial purposes.
The software must not be modified and distributed without prior
permission of the author.
But maybe it's worth to contact the authors and try to convince them to
allow a usage with libLAS ...
Volker
More information about the Liblas-devel mailing list
