[Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann wichmann at laserdata.at
Mon Jun 8 09:53:04 EDT 2009
Howard Butler wrote:
> You will need to run ./autogen.sh as automake and libtoolize need to
> be rerun due to some new macros being implemented.
> Howard
Thanks, that worked. Also the psid seems to be written correctly now - I
just did a quick check with lasinfo. But I had to use an older version
of lasinfo to get it printed, it would be nice if the version in trunk
could be extended to print it again.
Thanks again for your help,
Volker
More information about the Liblas-devel mailing list
