[Liblas-devel] txt2las - psid only 1 byte?
Howard Butler hobu.inc at gmail.com
Mon Jun 8 11:25:31 EDT 2009
On Jun 8, 2009, at 8:53 AM, Volker Wichmann wrote:
> Howard Butler wrote:
>> You will need to run ./autogen.sh as automake and libtoolize need
>> to be rerun due to some new macros being implemented.
>> Howard
> Thanks, that worked. Also the psid seems to be written correctly now
> - I just did a quick check with lasinfo. But I had to use an older
> version of lasinfo to get it printed, it would be nice if the
> version in trunk could be extended to print it again.
hmm... do you think that lasinfo is interpreting it as a byte instead
of a short?  Please add more details to that bug and I will look into
it.
Howard
More information about the Liblas-devel mailing list
