[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Howard Butler hobu.inc at gmail.com
Tue May 26 13:26:13 EDT 2009
On May 25, 2009, at 10:40 AM, Jeff Hamann wrote:
> I'm trying to get liblas-1.0.1 to build on my FreeBSD64 machines and
> discovered that the compiler that's getting used is gcc 3.4.4, which
> compiles and links the 1.0.1 source, but yields the following
> results for example:
>  Min X Y Z                  0.000000 0.000000
> 738736861263988851298380279202391078391644568474981382591204550317796735641019245818295007277452811570850587484972658344932700484666392576.000000
eek, we have only built and tested on gcc 4.0+
I would note there is a 1.2 release of libLAS available, but I doubt
it resolves this issue.  I will look into it.  If you could please
file a bug at http://liblas.org with this message, I will try to
investigate it as soon as possible.
Thanks for the report,
Howawrd
More information about the Liblas-devel mailing list
