[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Howard Butler hobu.inc at gmail.com
Tue May 26 17:41:03 EDT 2009
On May 26, 2009, at 12:26 PM, Howard Butler wrote:
> On May 25, 2009, at 10:40 AM, Jeff Hamann wrote:
>> I'm trying to get liblas-1.0.1 to build on my FreeBSD64 machines
>> and discovered that the compiler that's getting used is gcc 3.4.4,
>> which compiles and links the 1.0.1 source, but yields the following
>> results for example:
>> Min X Y Z                  0.000000 0.000000
>> 738736861263988851298380279202391078391644568474981382591204550317796735641019245818295007277452811570850587484972658344932700484666392576.000000
> eek, we have only built and tested on gcc 4.0+
I tested with gcc 3.4 on ubuntu intrepid and 'make check' all passed.
I suspect the problem is related to the data type macros in <liblas/
cstdint.hpp> and poor interactions with BSD.
> After doing a little research, it looks like I need a compiler
> that's a little more recent, which I have, but I'm not sure how to
> tell ./configure to use the more recent compiler. Since I'm somewhat
> of a newbie with libtool, automake, and autoconf, does anyone have a
> suggestion for simply telling ./configure (or mod'n the inputs) to
> require gcc 4.1+?
define them as variables on your configure line (note the switch for
the spatial indexing and OCI stuff is svn trunk only at this point):
CC="/usr/bin/gcc-3.4" CXX="/usr/bin/gcc-3.4" ./configure        --with-
gdal=/usr/bin/gdal-config \
		--with-oci=yes \
                 --with-spatialindex=/usr/local \
                 --with-geotiff=/usr \
                 --enable-debug
Hope this helps,
Howard
More information about the Liblas-devel mailing list
