[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Mateusz Loskot mateusz at loskot.net
Wed May 27 18:06:46 EDT 2009
Jeff Hamann wrote:
> I'm trying to get liblas-1.0.1 to build on my FreeBSD64 machines and
> discovered that the compiler that's getting used is gcc 3.4.4, which
> compiles and links the 1.0.1 source, but yields the following results
> for example:
> $ lasinfo lidar.las
>   Header Summary
>   File Name: lidar.las
>   Version:                    1.0
>   Source ID:                  0
>   Reserved:                   0
>   Project ID/GUID:           '00000000-0000-0000-0000-000000000000'
>   System Identifier:         ''
>   Generating Software:       'TerraScan'
>   File Creation Day/Year:    0/0
>   Header Size                227
>   Offset to Point Data       -452984832
>   Number Var. Length Records 0
>   Point Data Format          1
>   Point Data Record Length   28
>   Number of Point Records    -261525504
>   Number of Points by Return 0 -783548416 295895808 -1851190784 2110806272
>   Scale Factor X Y Z         7.68817e+284 7.68817e+284 7.68817e+284
>   Offset X Y Z               0.000000 0.000000 0.000000
>   Min X Y Z                  0.000000 0.000000
> 738736861263988851298380279202391078391644568474981382591204550317796735641019245818295007277452811570850587484972658344932700484666392576.000000
>   Max X Y Z                  0.000000 -0.000000 -0.000000
>  Spatial Reference
> After doing a little research, it looks like I need a compiler that's a
> little more recent, which I have, but I'm not sure how to tell
> ./configure to use the more recent compiler. Since I'm somewhat of a
> newbie with libtool, automake, and autoconf, does anyone have a
> suggestion for simply telling ./configure (or mod'n the inputs) to
> require gcc 4.1+?
> Also, if any of this helps...
> $ uname -a
> FreeBSD bobby.forestinformatics.com 6.0-RELEASE FreeBSD 6.0-RELEASE #2:
> Sun Nov 27 14:07:55 PST 2005
> hamannj at bobby.forestinformatics.com:/usr/obj/usr/src/sys/GENERIC  amd64
> $ gcc --version
> gcc (GCC) 3.4.4 [FreeBSD] 20050518
> Copyright (C) 2004 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Jeff,
I have tested libLAS from current SVN trunk on FreeBSD 7.2 (amd64)
Here is complete log: http://osgeo.pastebin.com/d6a6344cd
I don't remember which version of compiler I used (I can check it
tomorrow), though I'm quite sure it's 4.x line. Everything works as here:
[mloskot@ ~/dev/liblas/_svn/trunk]$ uname -a
FreeBSD vb-freebsd72-amd64 7.2-RELEASE FreeBSD 7.2-RELEASE #0: Fri May
1 07:18:07 UTC 2009
root at driscoll.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC  amd64
[mloskot@ ~/dev/liblas/_svn/trunk]$ make check
make  check-TESTS
libLAS Test Suite:
liblas::LASClassification: ..............................
liblas::LASError: ...Failed to remove '../data//lasfile_tmp.las' file
liblas::LASFile: .Failed to remove '../data//lasfile_tmp.las' file
liblas::LASHeader: ............
liblas::LASPoint: ................
liblas::LASReader: .......
liblas::LASSpatialReference: .
liblas::LASVariableRecord: ......
liblas::LASWriter: ....
liblas::guid: .......
liblas::lasreader_iterator: ......................
tests summary: ok:118
PASS: liblas_test
All 1 tests passed
[mloskot@ ~/dev/liblas/_svn/trunk]$ ./apps/lasinfo test/data/srs.las
  Header Summary
  File Name: test/data/srs.las
  Version:                    1.0
  Source ID:                  0
  Reserved:                   0
  System Identifier:         'MODIFIED'
  Header Size                227
  Offset to Point Data       759
  Number Var. Length Records 3
  Point Data Format          1
  Number of Point Records    10
  Number of Points by Return 10 0 0 0 0
  Scale Factor X Y Z         0.01 0.01 0.01
  Offset X Y Z               -0.000000 -0.000000 -0.000000
  Min X Y Z                  289814.150000 4320978.610000 170.580000
  Max X Y Z                  289818.500000 4320980.590000 170.760000
 Spatial Reference
  VLR Summary
   User: 'LASF_Projection' - Description: ''
   ID: 34735 Length: 72
   ID: 34736 Length: 40
   ID: 34737 Length: 256
Have you tried to run tests?
If not, could you issue "make check" command?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
