[Liblas-devel] LAS SHP Viewer
Etienne Bellemare Racine
etiennebr at gmail.com
Wed Aug 25 15:22:32 EDT 2010
Hi Michael,
Depending of the way you want to visualize your data and the kind of
shapefile you have, maybe SAGA <http://www.saga-gis.org/en/index.html>
could be a good choice. Otherwise, I find that Fusion/LDV
<http://forsys.cfr.washington.edu/fusion/fusionlatest.html> is a good 3D
las visualizer but I'm not sure about viewing 3D shapefile. There is
also GRASS <http://grass.osgeo.org/> that allows to load both formats
(using liblas I think). If your data isn't too huge and you plan to
program something, maybe you could do that in R
<http://www.r-project.org/> as there is an OpenGL binding that could be
used for 3D and multiples shapefiles readers
<http://cran.r-project.org/web/views/Spatial.html>. However, for reading
las in R, you could write a liblas binding :-) or I know or use this
other initiative <http://staff.acecrc.org.au/%7Emdsumner/las/readLAS.R>.
Hope it helps,
Etienne
Le 2010-08-25 13:38, Black, Michael (IS) a écrit :
> Does anybody know a decent combined LAS and SHP viewer?
> All the stuff I've found is too clunky to just view both types of
> files easily (like instantiating it from a command line 'view data.las
> data.shp').
> I have tried Mars Explorer and PointVue.
> I'm about ready to write my own. If anybody has source for a decent
> LAS Viewer I can add SHP files to it.
> Michael D. Black
> Senior Scientist
> Advanced Analytics Directorate
> Northrop Grumman Information Systems
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100825/ca0c33a0/attachment.html
More information about the Liblas-devel
