[Liblas-devel] Error reading two Terrascan .BIN file
Howard Butler
hobu.inc at gmail.com
Wed May 12 17:19:45 EDT 2010
On May 12, 2010, at 8:12 AM, jeet_sen wrote:
> HI,
> I am trying to compare two .BIN files in Windows (VS2008).
> Since I do not have the BIn file structure standard, I am following the
> structure as defined in ts2las.hpp available in ts2las utility.
> As per the structure defined:
> Header = 56 bytes
> ScanPnt = 24 bytes
> Now to compare two files, I read the points simultaneously one after the
> other like this:
> (strmI and strmO are my two file streams containing same no of record
> points)
> std::cout << "Istream position is: " << strmI->tellg() << std::endl;
> std::cout << "Ostream position is: " << strmO->tellg() << std::endl;
Is strmO an ostream or istream?
Please show more code, this isn't enough to see what's going on.
More information about the Liblas-devel
