[Liblas-devel] Error reading two Terrascan .BIN file
jeet_sen
suvajit at sce.co.in
Thu May 13 03:39:09 EDT 2010
Hi Howard,
Here is the function which reads two .BIN files and dumps the classification
difference into the third file.
The Header for both the streams of file1 & file2 has been read before
calling the function and also ensured that the bin files are same with equal
number of point record count .
* RecordClassDiff
* args
* istream* strmI Input stream for bin file1
* istream* strmO Input stream for bin file2
* ostream* writer Output stream for diff file
* ScanHdr* hdr Scanned header of file1
* return
* bool - true if diff generated successfully
bool RecordClassDiff(std::istream* strmI, std::istream* strmO, std::ostream*
writer,ScanHdr* hdr){
ScanPnt* pointI = new ScanPnt;
ScanRow* rowI = new ScanRow;
ScanPnt* pointO = new ScanPnt;
ScanRow* rowO = new ScanRow;
int index = 0;
int count = 1;
while (true)
try
std::cout << "Istream position is: " << strmI->tellg() <<
std::endl;
std::cout << "Ostream position is: " << strmO->tellg() << std::endl;
if (hdr->HdrVersion == 20020715) {
// Read scan point from file1
detail::read_n(*pointI, *strmI, sizeof(ScanPnt));
// Read scan point from file2
detail::read_n(*pointO, *strmO, sizeof(ScanPnt));
} else{
//read scan point for file1
detail::read_n(*rowI, *strmI, sizeof(ScanRow));
pointI->Pnt.x = rowI->x;
pointI->Pnt.y = rowI->y;
pointI->Pnt.z = rowI->z;
pointI = rowI->Code;
pointI->Line = rowI->Line;
pointI->Intensity = rowI->EchoInt & 0x3FFF;
pointI->Echo = (rowI->EchoInt >> 14);
//read scan point for file2
detail::read_n(*rowO, *strmO, sizeof(ScanRow));
pointO->Pnt.x = rowO->x;
pointO->Pnt.y = rowO->y;
pointO->Pnt.z = rowO->z;
pointO->Code = rowO->Code;
pointO->Line = rowO->Line;
pointO->Intensity = rowO->EchoInt & 0x3FFF;
pointO->Echo = (rowO->EchoInt >> 14);
Classification classI = Classification(pointI->Code);
Classification classO = Classification(pointO->Code);
int classIName = classI.GetClass();
int classOName = classO.GetClass();
// Compare and record diff
if ( classIName != classOName ) {
*writer << index << " " << classIName << " " << classOName <<
" " << std::endl;
count++;
// Reading remaining data to increment pointers to next
record
if (hdr->Time) {
liblas::uint32_t tI = 0xFFFFFFFF;
liblas::uint32_t tO = 0xFFFFFFFF;
detail::read_n(tI, *strmI, sizeof(tI));
detail::read_n(tO, *strmI, sizeof(tO));
if (hdr->Color) {
liblas::uint8_t rI, gI, bI, aI = 0;
liblas::uint8_t rO, gO, bO, aO = 0;
detail::read_n(rI, *strmI, sizeof(rI));
detail::read_n(bI, *strmI, sizeof(bI));
detail::read_n(gI, *strmI, sizeof(gI));
detail::read_n(aI, *strmI, sizeof(aI));
detail::read_n(rO, *strmI, sizeof(rO));
detail::read_n(bO, *strmI, sizeof(bO));
detail::read_n(gO, *strmI, sizeof(gO));
detail::read_n(aO, *strmI, sizeof(aO));
//Increment index
index++;
catch (std::out_of_range) // we reached the end of the file
std::cout << "catching out of range error!" << std::endl;
std::cout << "Point read : " << index << std::endl;
std::cout << "Total diffs : " << count << std::endl;
return true;
catch (std::exception const& e) // we reached the end of the
file
std::cout << e.what() << std::endl;
break;
delete pointI;
delete rowI;
delete classI;
delete pointO;
delete rowO;
delete classO;
return true;
Regards,
Suvajit Sengupta
www.sce.co.in
we guide your way
View this message in context: http://liblas-developers.431198.n3.nabble.com/Error-reading-two-Terrascan-BIN-file-tp812436p814363.html
Sent from the libLAS Developers mailing list archive at Nabble.com.
More information about the Liblas-devel
