[Liblas-devel] Re: ./configure --with-gdal
Peter Tittmann pwtittmann at ucdavis.edu
Thu May 20 19:21:29 EDT 2010
Just FYI I resolved problem 2 by placing the following in my .bashrc:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
obviously my bash savvy is lacking.....
Peter
>  Hi,
>  I've migrated to on Ubuntu 10.0.4 LTS and am having some issues with
>  liblas install.
>  GDAL:
>  Ive installed the latest stable version (1.7.2) from source.
>  LIBGEOTIFF:
>  Ive installed the latest version (1.3.0) from source.
>  LinLAS:
>  http://trac.liblas.org/attachment/wiki/1.2.1/liblas-src-1.2.1.tar.gz
>  Problem 1 references the previous email whihc I was never able to resolve:
>  when running ./configure --with-gdal --with-geotiff=/usr/lib
>  i get this:
>  checking for stdio.h... yes
>  checking for stdlib.h... (cached) yes
>  checking for debug enabled... no
>  checking for GDAL... GDAL enabled with gdal-config found in PATH
>  /usr/local/bin/gdal-config reports version 1.7.2
>  checking for ST_Create in -lgeotiff... no
>  checking for libgeotiff... no
>  configure: error: You must configure a libgeotiff if you are using GDAL
>  binaries.  You can configure using a GDAL source tree without
>  libgeotiff, but not from binaries.
>  so i resigned to not having GDAL and ran ./configure make make install
>  with no errors wihc lead to Problem2:
>  when I try to use the command line tools i get the following:
>  $ lasinfo ~/Documents/LiDAR/laswork/big_sub19_fr.las
>  lasinfo: error while loading shared libraries: liblas.so.1: cannot open
>  shared object file: No such file or directory
>  Thanks in advance for any guidance.
>  Best,
>  Peter
More information about the Liblas-devel mailing list
