[Liblas-devel] las to tin conversion
Bekbolat Zhaidarbayuli zhaidar.1980 at gmail.com
Tue May 25 10:58:56 EDT 2010
Hi All,
I was using the las2tin.exe application, to get the first only and last only
points' tin
for example:
las2tin -i a.las -o a-last.txt -last_only
extra pass reading 4599654 points to determine which we keep ...
eliminated based on last returns only: 295681
reading 4599654 points and triangulating 4303973 points
outputting the triangles ...
next time for first only
las2tin -i a.las -o a-first.txt -first_only
eliminated based on first returns only: 294030
reading 4599654 points and triangulating 4305624 points
In the last only case: 4303973 points triangulated
In the first only case: 4305624 points triangulated
Total I have: 4599654 points
Does this mean that some of the points are considered to be both first and
last?
I would be happy if someone could shed some light into this...
Thanks,
Beka
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100525/cc225500/attachment.html
More information about the Liblas-devel mailing list
