[Liblas-devel] dev version doesn't build
J Luis
jmfluis at gmail.com
Sun Sep 5 08:18:55 EDT 2010
I tried to build the dev version but I simply was not able to pass the Boost step (very confusing).
To start with, Cmake is not able to find Boost by itself (!?)
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindBoost.cmake:910 (message):
Unable to find the requested Boost libraries.
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
So, as recomended, I did try to set
set BOOST_ROOT="C:\Program Files (x86)\boost\boost_1_44"
or
set BOOST_ROOT="C:\Program Files (x86)\boost\boost_1_44\boost"
but error are the same.
BTW, what does it mean by "to the directory containing Boost libraries..."
There isn't one single .lib inside the entire Boost installation!!
Next I tried to set the Boost_INCLUDE_DIR inside Cmake to (that's where I find the .hpp files)
Result:
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindBoost.cmake:522 (FILE):
file Internal CMake error when trying to open file: C:\Program Files
(x86)\boost\boost_1_44\boost/boost/version.hpp for reading.
Call Stack (most recent call first):
Obvious. The "version.hpp" is under
...boost_1_44\boost/version.hpp
not
...boost_1_44\boost/boost/version.hpp
Joaquim Luis
More information about the Liblas-devel
