[Liblas-devel] dev version doesn't build
Howard Butler
hobu.inc at gmail.com
Mon Sep 6 16:35:48 EDT 2010
On Sep 5, 2010, at 7:18 AM, J Luis wrote:
> BTW, what does it mean by "to the directory containing Boost libraries..."
> There isn't one single .lib inside the entire Boost installation!!
Joaquim,
How did you install Boost? I admit that our Boost finding tools aren't so great, and I have had a bit of trouble with them as well on windows, but I have had good success by installing the binaries from boostpro.com and choosing the program_options library with all build types. By default, libLAS wants to statically link the multithreaded DLL for program_options and boost_serialization (all other Boost usage in libLAS is headers-only AFAIK), so make sure you have these library types installed. If you are building Boost yourself, this means investigating and using the options necessary in bjam (yuck!, btw, I hope they officially upgrade to CMake) to get the build type you need.
Hope this helps,
Howard
More information about the Liblas-devel
