[Liblas-devel] Build Failure in Microsoft Visual C++ 2010
francesco francesco.pirotti at unipd.it
Fri Apr 15 11:48:09 EDT 2011
Are you sure you have the exact lib in boost? There are several types,
(xxxxxx-mt-xxxxxx) indicates multithreaded for example whereas
(xxxxx-mt-s-xxxxxx) is multithreaded and static. Are you compiling
static or dynamic? Maybe others in the list can help you better. Best of
luck.
Cheers,
Francesco
Il 15/04/2011 16:32, sdellyta at hsr.ch ha scritto:
> Hi,
> I am quite a newbie in this Liblas. I would like to compile Liblas and modified it in order to have a WKT format instead of ASCII.
> However, I have several problem while I am building the source code. I am following this link to compile
> http://liblas.org/compilation.html#compilation
> I am using Window 7. In adition, I am using Boost 1.46.1 and CMake 2.8
> Here are the errors that make the build process failed:
> 1>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc100-mt-gd-1_46_1.lib'
> 2>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc100-mt-gd-1_46_1.lib'
> Surprisingly, I can find the .lib in my boost folder. I have no idea why this error can come up.
> FYI, I only build the las2txt.
> Attached is the detail of error logs.
> Any help I'll really appreciate much.
> Thank you.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
*Francesco Pirotti*
Dep. TESAF
CIRGEO -- Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Phone: +39 049 827 2710
Phone: +39 349 55 39 261
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110415/45a0af53/attachment.html
More information about the Liblas-devel mailing list
