[Liblas-devel] Build Failure in Microsoft Visual C++ 2010
Michael P. Gerlek mpg at flaxen.com
Fri Apr 15 12:02:01 EDT 2011
Mike, didn't you have a very similar issue to this in Toronto?
-mpg
[mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of francesco
Sent: Friday, April 15, 2011 8:48 AM
To: liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] Build Failure in Microsoft Visual C++ 2010
Are you sure you have the exact lib in boost? There are several types,
(xxxxxx-mt-xxxxxx) indicates multithreaded for example whereas
(xxxxx-mt-s-xxxxxx) is multithreaded and static. Are you compiling static or
dynamic? Maybe others in the list can help you better. Best of luck.
Cheers,
Francesco
Il 15/04/2011 16:32, sdellyta at hsr.ch ha scritto:
I am quite a newbie in this Liblas. I would like to compile Liblas and
modified it in order to have a WKT format instead of ASCII.
However, I have several problem while I am building the source code. I am
following this link to compile
http://liblas.org/compilation.html#compilation
I am using Window 7. In adition, I am using Boost 1.46.1 and CMake 2.8
Here are the errors that make the build process failed:
1>LINK : fatal error LNK1104: cannot open file
'libboost_thread-vc100-mt-gd-1_46_1.lib'
2>LINK : fatal error LNK1104: cannot open file
Surprisingly, I can find the .lib in my boost folder. I have no idea why
this error can come up.
FYI, I only build the las2txt.
Attached is the detail of error logs.
Any help I'll really appreciate much.
Thank you.
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
Francesco Pirotti
Dep. TESAF
CIRGEO - Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it
Phone: +39 049 827 2710
Phone: +39 349 55 39 261
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110415/5d867a87/attachment.html
More information about the Liblas-devel mailing list
