[Liblas-devel] libLAS file size limit
Volker Wichmann
wichmann at laserdata.at
Mon Jan 17 07:51:07 EST 2011
Am 17.01.2011 04:40, schrieb Howard Butler:
> On Jan 16, 2011, at 6:22 PM, Volker Wichmann wrote:
>> Hi,
> Does a linux or OSX build complain about the file with the same
> error? If so, then the above commentary is wrong and it might
> actually be something with the file, but considering you can
> sequentially read through it, I doubt it.
No problems under linux 64bit - seems like your explanation is correct!
I'll update to MSVC10,
thanks!
Volker
More information about the Liblas-devel
