[Liblas-devel] libLAS file size limit
Volker Wichmann
wichmann at laserdata.at
Fri Jan 28 19:26:05 EST 2011
Am 17.01.2011 13:51, schrieb Volker Wichmann:
> Am 17.01.2011 04:40, schrieb Howard Butler:
>> On Jan 16, 2011, at 6:22 PM, Volker Wichmann wrote:
>>> Hi,
>> Does a linux or OSX build complain about the file with the same
>> error? If so, then the above commentary is wrong and it might
>> actually be something with the file, but considering you can
>> sequentially read through it, I doubt it.
> No problems under linux 64bit - seems like your explanation is correct!
> I'll update to MSVC10,
Just as a follow up - updating to MSVC10 resolves the issue.
Volker
More information about the Liblas-devel
