[Liblas-devel] libLAS file size limit
Howard Butler hobu.inc at gmail.com
Fri Jan 28 20:44:22 EST 2011
On Jan 28, 2011, at 6:26 PM, Volker Wichmann wrote:
> Am 17.01.2011 13:51, schrieb Volker Wichmann:
>> Am 17.01.2011 04:40, schrieb Howard Butler:
>>> On Jan 16, 2011, at 6:22 PM, Volker Wichmann wrote:
>>>> Hi,
>>> Does a linux or OSX build complain about the file with the same
>>> error? If so, then the above commentary is wrong and it might
>>> actually be something with the file, but considering you can
>>> sequentially read through it, I doubt it.
>> No problems under linux 64bit - seems like your explanation is correct!
>> I'll update to MSVC10,
> Just as a follow up - updating to MSVC10 resolves the issue.
Additionally, I have removed the logic that seeked to determine the point count.  The value in the header is now always believed, whatever the consequence.
Howard
More information about the Liblas-devel mailing list
