Re: [Liblas-devel] IDE used/good for using Liblas
Ivan Lucena ivan.lucena at pmldnet.com
Wed Jun 22 10:04:53 EDT 2011
Microsoft Visual Studio ( VS 2008 C++ Express Edition is free ).
>  -------Original Message-------
>  From: thejus kambi <thejus.kambi at gmail.com>
>  To: Ivan Lucena <ivan.lucena at pmldnet.com>
>  Cc: liblas-devel at lists.osgeo.org
>  Subject: Re: [Liblas-devel] IDE used/good for using Liblas
>  Sent: Jun 22 '11 08:40
>  hmm, I am using Window.
>  On Wed, Jun 22, 2011 at 3:32 PM, Ivan Lucena <[LINK:
>  mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
>  Thejus,
>  If ( OS != Win )
>   [LINK: http://netbeans.org] netbeans.org
>  See example of how to set it up: [LINK:
>  http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithNetBeansIDE]
>  All it does is to parse your C/C++ code in order to do auto-completion,
>  goto definition, find usage, refactoring and things like that. You
>  don't to create a project definition because it will use the original
>  makefiles. You can also use netbeans as a SVN, CVS or Mercurial front-end.
>  For debugging it will use the GDB installed in your system.
>  Regards,
>  Ivan
>  >  From: thejus kambi <[LINK: mailto:thejus.kambi at gmail.com]
>  >  To: [LINK: mailto:liblas-devel at lists.osgeo.org]
>  >  Subject: [Liblas-devel] IDE used/good for using Liblas
>  >  Sent: Jun 22 '11 08:01
>  >  Hello,
>  >  It could be a very basic question, Please bear with me, I am new to
>  c++.
>  >  Could you suggest me a good IDE for using liblas?
>  >  Thanks in advance,
>  >  Thejus
>  >  _______________________________________________
>  >  Liblas-devel mailing list
>  >  [LINK: compose.php?to=[LINK: mailto:Liblas-devel at lists.osgeo.org]
>  >  [LINK: [LINK: http://lists.osgeo.org/mailman/listinfo/liblas-devel]
More information about the Liblas-devel mailing list
