[Liblas-devel] problem with reinstalling liblas in Python
Stanley Wong s.wong at kucerainternational.com
Tue Sep 20 08:48:52 EDT 2011
Andrej,
Please check if you have a python.exe in c:\OSGeo4W\bin\
If so, try this:
1. Open OSGeo4W shell, then type in
2. c:\OSGeo4W\bin\python.exe <your_script>.py
Stanley
----- Original Message -----
To: liblas-devel at lists.osgeo.org
Sent: Tuesday, September 20, 2011 5:27:01 AM
Subject: [Liblas-devel] problem with reinstalling liblas in Python
I have a problem with reinstalling liblas in Python and any help would be much appreciated.
Since I know next to nothing about compilers, the recipe how to install liblas with Python ( http://liblas.org/osgeo4w.html ) was a life-saver for me. However I somehow succeeded in ruining my liblas installation and I am unable to recreate it, even by following the exact same steps as the first time. Short description of the situation:
    1. In MS Windows XP I installed liblas on top of Pythonxy environment ( http://code.google.com/p/pythonxy/ ) following the recipe. At this point liblas worked perfectly with Python.
    2. Due to some unrelated problems I had to remove Python (using Windows / Add and remove programs). Unfortunately, after reinstalling Python and then executing liblas command from OSGeo4W shell, Python could not find liblas, reporting ImportError: No module named liblas.
    3. I got the same response from Python even after downloading and running the OSGeo4W installer again.
Kind regards and big thanks for your help,
Andrej
Dr. Andrej Kobler
Slovenian Forestry Institute
Večna pot 2, SI - 1000 Ljubljana, Slovenia
Phone +386 1 2007835
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110920/0e2bddaa/attachment.html
More information about the Liblas-devel mailing list
