[Liblas-devel] Can Liblas only update a small portion of the
points in Lidar file?
Martin Isenburg
martin.isenburg at gmail.com
Fri Feb 10 12:10:05 EST 2012
Make sure you disable the feature when the file is laszipped. There is
*no* way to add this. However, we could - in theory - support the
appending of points to an exsiting LAZ file.
cheers,
martin
On Fri, Feb 10, 2012 at 8:49 AM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Feb 8, 2012, at 12:41 PM, Hongwei Shen wrote:
>> To solve this problem, I think we can add a member variable, m_AbsoluteIndex, to liblas::Point. Then we can also store the absolute index of the point in liblas::detail::ReadNextPoint() .
> I think I'm ok with this as long as the tests continue to pass.
>> To implement a ReaderUpdater (or ReaderWriter), I think we can do the following:
>> 1.
>> Add ReaderUpdaterI in liblas.hpp:
>> 2.
>> Add a class, liblas:detail:ReaderUpdater
>> 3.
>> Of course, add class liblas::ReaderUpdater to wrap liblas::detail::ReaderUpdater
>> How do you think of these changes? Will they break current design and/or other software that use liblas?
> This looks ok to me as well.
> Please implement this in your github fork and send the libLAS tree a pull request when you are complete. I'll pull it down and make sure everything continues to pass and we'll push it out in a new release.
> Thanks for the effort!
> Howard
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
