[Liblas-devel] error link in compile Error
Michael P. Gerlek
mpg at flaxen.com
Mon Jan 2 14:37:50 EST 2012
I think we’ve seen this before - try using the latest laszip sources (from github), not the one inside OSGeo4W.
-mpg
From: liblas-devel-bounces at lists.osgeo.org [mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of ???
Sent: Monday, December 26, 2011 9:34 PM
To: liblas-devel at lists.osgeo.org
Subject: [Liblas-devel] error link in compile Error
hi,all
i'also have the same error with the philipp when compliation with vs2010 and win7 .
firstly ,i use the laszip.lib in the osgeo4w ,the path is c:\osgeo4w\lib,but the error is the same of the philipp.
sceondly, i delete the laszip.lib in c:\osgeo4w\lib,delete laszip.dll in c:\osgeo4w\bin
and then i download the source code of laszip 2.0.2 and complie it ,and then put the laszip.lib into
c:\osgwo4w\lib , laszip.dll to c:\osgeo4w\bin, and update the .hpp in c:\osgeo4w\include
but the result is the same of the philipp.
can you help me?
philipp 's email is followed:
Hi all,
I want to compile libLAS with Visual Studio 2010 under Windows 7 (x86).
I’ve installed all the necessary dependencies (boost with all Variants,
OSGeo4W with gdal-devel, geotiff, oci, ...) and used the default
Directories to be as synchron as possible with the install-guide.
But I get this error all time:
Error 70 error LNK1120: 1 unresolved externals
C:\dev\libLAS\bin\Debug\liblas.dll liblas
Error 69 error LNK2019: unresolved external symbol "public:
char const * __thiscall LASitem::get_name(void)const "
(?get_name at LASitem <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @@QBEPBDXZ) referenced in function "public: class
liblas::property_tree::basic_ptree<class std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> >,class
std::basic_string<char,struct std::char_traits<char>,class
std::allocator<char>>,struct std::less<class std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> > > > __thiscall
liblas::Header::GetPTree(void)const "
(?GetPTree at Header <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @liblas@@QBE?AV?$basic_ptree at V <http://lists.osgeo.org/mailman/listinfo/liblas-devel> ?$basic_string at DU <http://lists.osgeo.org/mailman/listinfo/liblas-devel> ?$char_traits at D <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @std@@V?$allocator at D <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @2@@std@@V12 at U <http://lists.osgeo.org/mailman/listinfo/liblas-devel> ?$less at V <http://lists.osgeo.org/mailman/listinfo/liblas-devel> ?$basic_string at DU <http://lists.osgeo.org/mailman/listinfo/liblas-devel> ?$char_traits at D <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @std@@V?$allocator at D <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @2@@std@@@2@@property_tree at 2 <http://lists.osgeo.org/mailman/listinfo/liblas-devel> @XZ)
C:\dev\libLAS\src\header.cpp.obj liblas
Any idea ?
Thanks for any help,
philipp
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20120102/a708765a/attachment.html
More information about the Liblas-devel
