[Liblas-devel] error link in compile Error
Howard Butler
hobu.inc at gmail.com
Wed Jan 4 14:11:03 EST 2012
LASzip has been refreshed to LASzip 2.1.0, including the MSVC2008-based build on OSGeo4W. I have verified that the current head of libLAS builds with LASzip 2.1.0 when installed via OSGeo4W.
Howard
On Jan 2, 2012, at 1:37 PM, Michael P. Gerlek wrote:
> I think we’ve seen this before – try using the latest laszip sources (from github), not the one inside OSGeo4W.
> -mpg
> From: liblas-devel-bounces at lists.osgeo.org [mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of ???
> Sent: Monday, December 26, 2011 9:34 PM
> To: liblas-devel at lists.osgeo.org
> Subject: [Liblas-devel] error link in compile Error
> hi,all
> i'also have the same error with the philipp when compliation with vs2010 and win7 .
> firstly ,i use the laszip.lib in the osgeo4w ,the path is c:¥osgeo4w¥lib,but the error is the same of the philipp.
> sceondly, i delete the laszip.lib in c:¥osgeo4w¥lib,delete laszip.dll in c:¥osgeo4w¥bin
> and then i download the source code of laszip 2.0.2 and complie it ,and then put the laszip.lib into
> c:¥osgwo4w¥lib , laszip.dll to c:¥osgeo4w¥bin, and update the .hpp in c:¥osgeo4w¥include
> but the result is the same of the philipp.
> can you help me?
> philipp 's email is followed:
> Hi all,
> I want to compile libLAS with Visual Studio 2010 under Windows 7 (x86).
> I’ve installed all the necessary dependencies (boost with all Variants,
> OSGeo4W with gdal-devel, geotiff, oci, ...) and used the default
> Directories to be as synchron as possible with the install-guide.
> But I get this error all time:
> Error 70 error LNK1120: 1 unresolved externals
> C:¥dev¥libLAS¥bin¥Debug¥liblas.dll liblas
> Error 69 error LNK2019: unresolved external symbol "public:
> char const * __thiscall LASitem::get_name(void)const "
> (?get_name at LASitem@@QBEPBDXZ) referenced in function "public: class
> liblas::property_tree::basic_ptree<class std::basic_string<char,struct
> std::char_traits<char>,class std::allocator<char> >,class
> std::basic_string<char,struct std::char_traits<char>,class
> std::allocator<char>>,struct std::less<class std::basic_string<char,struct
> std::char_traits<char>,class std::allocator<char> > > > __thiscall
> liblas::Header::GetPTree(void)const "
> (?GetPTree at Header at liblas@@QBE?AV?$basic_ptree at V?$basic_string at DU?$char_traits at D at std@@V?$allocator at D at 2@@std@@V12 at U?$less at V?$basic_string at DU?$char_traits at D at std@@V?$allocator at D at 2@@std@@@2@@property_tree at 2 at XZ)
> C:¥dev¥libLAS¥src¥header.cpp.obj liblas
> Any idea ?
> Thanks for any help,
> philipp
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
