[Liblas-devel] Problem to import liblas module in Python 2.7
Howard Butler hobu.inc at gmail.com
Tue Mar 12 14:17:05 PDT 2013
Using laspy should not mean rewriting a ton of scripts. The interface of laspy is almost exactly the same as liblas (on purpose).
The error you are seeing is usually from the DLL being invalid for some reason. Did it get overwritten? Sorry I cannot provide any more information, but I am merely guessing given the error message and knowing nothing about your setup.
Howard
On Mar 12, 2013, at 3:52 PM, Alessandro Montaghi <alessandro.montaghi at gmail.com> wrote:
> Thnak Howard,
> but using laspy means rewrite one year of scripts. It much easier to fix how "today" i can not load liblas.
> Please, do you have some solution?
> Alessandro
> On Tue, Mar 12, 2013 at 9:46 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> You may find https://github.com/grantbrown/laspy more useful and easier to use (also, it is pure-python).
> HTH,
> Howard
> On Mar 12, 2013, at 3:34 PM, Alessandro Montaghi <alessandro.montaghi at gmail.com> wrote:
> >  I am using libals from months with windows 64-bit and Python 2.7 but today i got this message
> > from liblas import file lasfile
> > Traceback (most recent call last):
> > File "<interactive input>", line 1, in <module>
> > File "C:\Python27\lib\site-packages\liblas\__init__.py", line 2, in <module>
> > from core import
> >  get_version
> > File "C:\Python27\lib\site-packages\liblas\core.py", line 138, in <module>
> >     las
> > = ctypes.CDLL(os.path.join(local_dlls, lib_name))
> > File "C:\Python27\Lib\ctypes\__init__.py", line 365, in
> >  __init__
> > self._handle = _dlopen(self._name, mode)
> > WindowsError: [Error 193] %1 is not a valid Win32 application
> > I unistalled liblas, reinstalled but nothing. I unistall all Python 2.7, all module but nothing.
> > Thanks for your time because the use of libalas is essential for me
> > Thanks in advance
> > Alessandro
> > Alessandro Montaghi
> > just some stuff:
> > "Python where we can, C++ where we must"
> > Top 10 Things That Computer Programmers Hate:
> >      1. Waking Up Early
> >      2. Writing The F*cking Manual
> >      3. Not Drinking Coffee
> >      4. Reviewing Your Own Code 3 Months Later
> >      5. codes from other programmers without comments
> >      6. Error Checking
> >      7. (Not) Backing Up
> >      8. Debugging
> >      9. Leaving The House When Important Findings Come Up
> >     10. Mathematic or Physics Formulas
> > Liblas-devel mailing list
> > Liblas-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/liblas-devel
> Alessandro Montaghi
> just some stuff:
>      1. Waking Up Early
>      6. Error Checking
>      7. (Not) Backing Up
>      8. Debugging
More information about the Liblas-devel mailing list
