[Liblas-devel] Problem to import liblas module in Python 2.7
Alessandro Montaghi
alessandro.montaghi at gmail.com
Tue Mar 12 14:20:31 PDT 2013
I delete everything (also python27 directory) and re-install from zero
the "libLAS-1.7.0.win-amd64-py2.7.exe"
from http://www.lfd.uci.edu/~gohlke/pythonlibs/#numpy
On Tue, Mar 12, 2013 at 10:17 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> Using laspy should not mean rewriting a ton of scripts. The interface of
> laspy is almost exactly the same as liblas (on purpose).
> The error you are seeing is usually from the DLL being invalid for some
> reason. Did it get overwritten? Sorry I cannot provide any more
> information, but I am merely guessing given the error message and knowing
> nothing about your setup.
> Howard
> On Mar 12, 2013, at 3:52 PM, Alessandro Montaghi <
> alessandro.montaghi at gmail.com> wrote:
> > Thnak Howard,
> > but using laspy means rewrite one year of scripts. It much easier to fix
> how "today" i can not load liblas.
> > Please, do you have some solution?
> > Alessandro
> > On Tue, Mar 12, 2013 at 9:46 PM, Howard Butler <hobu.inc at gmail.com>
> wrote:
> > You may find https://github.com/grantbrown/laspy more useful and easier
> to use (also, it is pure-python).
> > HTH,
> > Howard
> > On Mar 12, 2013, at 3:34 PM, Alessandro Montaghi <
> > > I am using libals from months with windows 64-bit and Python 2.7 but
> today i got this message
> > > from liblas import file lasfile
> > > Traceback (most recent call last):
> > > File "<interactive input>", line 1, in <module>
> > > File "C:\Python27\lib\site-packages\liblas\__init__.py", line 2, in
> <module>
> > > from core import
> > > get_version
> > > File "C:\Python27\lib\site-packages\liblas\core.py", line 138, in
> <module>
> > > las
> > > = ctypes.CDLL(os.path.join(local_dlls, lib_name))
> > > File "C:\Python27\Lib\ctypes\__init__.py", line 365, in
> > > __init__
> > > self._handle = _dlopen(self._name, mode)
> > > WindowsError: [Error 193] %1 is not a valid Win32 application
> > > I unistalled liblas, reinstalled but nothing. I unistall all Python
> 2.7, all module but nothing.
> > > Thanks for your time because the use of libalas is essential for me
> > > Thanks in advance
> > > Alessandro
> > > Alessandro Montaghi
> > > just some stuff:
> > > "Python where we can, C++ where we must"
> > > Top 10 Things That Computer Programmers Hate:
> > > 1. Waking Up Early
> > > 2. Writing The F*cking Manual
> > > 3. Not Drinking Coffee
> > > 4. Reviewing Your Own Code 3 Months Later
> > > 5. codes from other programmers without comments
> > > 6. Error Checking
> > > 7. (Not) Backing Up
> > > 8. Debugging
> > > 9. Leaving The House When Important Findings Come Up
> > > 10. Mathematic or Physics Formulas
> > > _______________________________________________
> > > Liblas-devel mailing list
> > > Liblas-devel at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/liblas-devel
> > Alessandro Montaghi
> > just some stuff:
> > 1. Waking Up Early
> > 6. Error Checking
> > 7. (Not) Backing Up
> > 8. Debugging
Alessandro Montaghi
just some stuff:
*"Python where we can, C++ where we must"*
*Top 10 Things That Computer Programmers Hate:*
1. Waking Up Early
6. Error Checking
7. (Not) Backing Up
8. Debugging
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20130312/764b7313/attachment.html>
More information about the Liblas-devel
