[Liblas-devel] Problem to import liblas module in Python 2.7
Alessandro Montaghi alessandro.montaghi at gmail.com
Tue Mar 12 14:52:57 PDT 2013
i have also a liblas working on my home PC (64-bit and Python 2.7). I
copied and pasted the *.dll files from my Home PC to my Work Pc but i get
always the same error.
On Tue, Mar 12, 2013 at 10:20 PM, Alessandro Montaghi <
alessandro.montaghi at gmail.com> wrote:
> I delete everything (also python27 directory) and re-install from zero the  "libLAS-1.7.0.win-amd64-py2.7.exe"
> from http://www.lfd.uci.edu/~gohlke/pythonlibs/#numpy
> On Tue, Mar 12, 2013 at 10:17 PM, Howard Butler <hobu.inc at gmail.com>wrote:
>> Using laspy should not mean rewriting a ton of scripts. The interface of
>> laspy is almost exactly the same as liblas (on purpose).
>> The error you are seeing is usually from the DLL being invalid for some
>> reason. Did it get overwritten? Sorry I cannot provide any more
>> information, but I am merely guessing given the error message and knowing
>> nothing about your setup.
>> Howard
>> On Mar 12, 2013, at 3:52 PM, Alessandro Montaghi <
>> > Thnak Howard,
>> > but using laspy means rewrite one year of scripts. It much easier to
>> fix how "today" i can not load liblas.
>> > Please, do you have some solution?
>> > Alessandro
>> > On Tue, Mar 12, 2013 at 9:46 PM, Howard Butler <hobu.inc at gmail.com>
>> wrote:
>> > You may find https://github.com/grantbrown/laspy more useful and
>> easier to use (also, it is pure-python).
>> > HTH,
>> > Howard
>> > On Mar 12, 2013, at 3:34 PM, Alessandro Montaghi <
>> > >  I am using libals from months with windows 64-bit and Python 2.7 but
>> today i got this message
>> > > from liblas import file lasfile
>> > > Traceback (most recent call last):
>> > > File "<interactive input>", line 1, in <module>
>> > > File "C:\Python27\lib\site-packages\liblas\__init__.py", line 2, in
>> <module>
>> > > from core import
>> > >  get_version
>> > > File "C:\Python27\lib\site-packages\liblas\core.py", line 138, in
>> <module>
>> > >     las
>> > > = ctypes.CDLL(os.path.join(local_dlls, lib_name))
>> > > File "C:\Python27\Lib\ctypes\__init__.py", line 365, in
>> > >  __init__
>> > > self._handle = _dlopen(self._name, mode)
>> > > WindowsError: [Error 193] %1 is not a valid Win32 application
>> > > I unistalled liblas, reinstalled but nothing. I unistall all Python
>> 2.7, all module but nothing.
>> > > Thanks for your time because the use of libalas is essential for me
>> > > Thanks in advance
>> > > Alessandro
>> > > Alessandro Montaghi
>> > > just some stuff:
>> > > "Python where we can, C++ where we must"
>> > > Top 10 Things That Computer Programmers Hate:
>> > >      1. Waking Up Early
>> > >      2. Writing The F*cking Manual
>> > >      3. Not Drinking Coffee
>> > >      4. Reviewing Your Own Code 3 Months Later
>> > >      5. codes from other programmers without comments
>> > >      6. Error Checking
>> > >      7. (Not) Backing Up
>> > >      8. Debugging
>> > >      9. Leaving The House When Important Findings Come Up
>> > >     10. Mathematic or Physics Formulas
>> > > _______________________________________________
>> > > Liblas-devel mailing list
>> > > Liblas-devel at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/liblas-devel
>> > Alessandro Montaghi
>> > just some stuff:
>> >      1. Waking Up Early
>> >      6. Error Checking
>> >      7. (Not) Backing Up
>> >      8. Debugging
> Alessandro Montaghi
> just some stuff:
> *"Python where we can, C++ where we must"*
> *Top 10 Things That Computer Programmers Hate:*
>      1. Waking Up Early
>      6. Error Checking
>      7. (Not) Backing Up
>      8. Debugging
Alessandro Montaghi
just some stuff:
     1. Waking Up Early
     6. Error Checking
     7. (Not) Backing Up
     8. Debugging
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20130312/d0a7281b/attachment-0001.html>
More information about the Liblas-devel mailing list
