[Liblas-devel] compile error in gt_wkt_srs.cpp.o, git master
Eric Goddard egoddard1010 at gmail.com
Wed Feb 5 09:34:12 PST 2014
It appears the issue is due to a change in GDAL. I checked out GDAL
revision 26484 (September 2013) that I'm using on my desktop and which
libLAS successfully compiled against. With that GDAL revision I was able to
compile libLAS.
Eric
On Wed, Feb 5, 2014 at 4:09 AM, Mateusz Łoskot <mateusz at loskot.net> wrote:
> On 5 February 2014 03:33, Eric Goddard <egoddard1010 at gmail.com> wrote:
> > Hi all,
> > I've been compiling libLAS for quite awhile with no issues. While setting
> > everything up on a fresh install of Linux Mint 16, I'm running into some
> > problems compiling libLAS. The output from make is at:
> > http://paste.kde.org/p2c8da0bb
> This seems to be like known problem from the past,  it also (used to?)
> affect PDAL
> http://trac.osgeo.org/gdal/ticket/4374
> I haven't followed this further in PDAL, so I'm not sure if and how it
> is solved there now.
> Perhaps Howard has solution for that, I could try to apply it to libLAS.
> Best regards,
> Mateusz  Łoskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20140205/fa9699a2/attachment.html>
More information about the Liblas-devel mailing list
