[Live-demo] Arramagong_GISVM_FOSS4G2009_alpha1
Ricardo Pinho
rpinho_eng at yahoo.com.br
Mon Aug 31 17:40:19 EDT 2009
Second note about:
Arramagong_GISVM_FOSS4G2009_alpha1.7z
(1. gvSIG in Spanish)
2. Reduce vmdk disk file size:
After un7zip the vmdk file turns out to:
5 297 602 560 bytes
A kick way to reduce this is to run VMWare Tools Shrink command
(inside the virtual machine - run the following command on terminal)
> sudo vmware-toolbox
Then select Shrink + "/" + shrink
After a couple of minutes you get a vmdk with:
4 339 466 240 bytes
It is still a huge file... but it can easy the distribution a bit ;-)
Cheers,
Ricardo
----- Mensagem original ----
De: Ricardo Pinho <rpinho_eng at yahoo.com.br>
Para: Stefan Hansen <stefan.hansen at lisasoft.com>
Enviadas: Quinta-feira, 27 de Agosto de 2009 12:11:12
Assunto: Re: [Live-demo] questions
> In which folder should we store documentation?
Don't know for sure which documentation you are talking about.
But I can remind this:
On GISVM there is a Samba Shared folder named: /home/user/gisdata
On the next version of "GISVM Server" it is planned to include a Dropbox folder: /home/user/Dropbox
Both of them can be used to include Documentation, so it can be easily access from outside (GISVM) and updated.
> You installed gvSIG into /home/user.
> Can I move it somewhere
> else or do you have a special reason to keep it there?
Yes you can. Just beware of user file access rights!
Cheers,
RP
De: Stefan Hansen <stefan.hansen at lisasoft.com>
Para: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
Enviadas: Quinta-feira, 27 de Agosto de 2009 9:21:36
Assunto: [Live-demo] questions
Hi!
I just have some quick questions:
Ricardo: You installed gvSIG into /home/user. Can I move it somewhere
Some install-scripts (udig and grass so far) install sample data. For
last years DVD we had some additional data sets. Most of them were
loaded into Postgres. Do we want to do that again this year?
cheers,
stefan
Stefan Hansen
Software Engineer
LISAsoft
Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
Level 9, 601 Bourke St, Melbourne Vic 3000
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
____________________________________________________________________________________
Veja quais são os assuntos do momento no Yahoo! +Buscados
http://br.maisbuscados.yahoo.com
More information about the Live-demo
