[Live-demo] Arramagong_GISVM_FOSS4G2009_alpha1
Cameron Shorter
cameron.shorter at lisasoft.com
Mon Aug 31 19:16:05 EDT 2009
Ricardo,
That sounds like good advice.
I suggest that we create a distribution.sh script, which would include
the compressing as you suggest, and zipping up, adding version number etc.
Ricardo Pinho wrote:
> Second note about:
> Arramagong_GISVM_FOSS4G2009_alpha1.7z
> (1. gvSIG in Spanish)
> 2. Reduce vmdk disk file size:
> After un7zip the vmdk file turns out to:
> 5 297 602 560 bytes
> A kick way to reduce this is to run VMWare Tools Shrink command
> (inside the virtual machine - run the following command on terminal)
>> sudo vmware-toolbox
> Then select Shrink + "/" + shrink
> After a couple of minutes you get a vmdk with:
> 4 339 466 240 bytes
> It is still a huge file... but it can easy the distribution a bit ;-)
> Cheers,
> Ricardo
> ----- Mensagem original ----
> De: Ricardo Pinho <rpinho_eng at yahoo.com.br>
> Para: Stefan Hansen <stefan.hansen at lisasoft.com>
> Enviadas: Quinta-feira, 27 de Agosto de 2009 12:11:12
> Assunto: Re: [Live-demo] questions
>> In which folder should we store documentation?
> Don't know for sure which documentation you are talking about.
> But I can remind this:
> On GISVM there is a Samba Shared folder named: /home/user/gisdata
> On the next version of "GISVM Server" it is planned to include a Dropbox folder: /home/user/Dropbox
> Both of them can be used to include Documentation, so it can be easily access from outside (GISVM) and updated.
>> You installed gvSIG into /home/user.
>> Can I move it somewhere
>> else or do you have a special reason to keep it there?
> Yes you can. Just beware of user file access rights!
> Cheers,
> RP
> De: Stefan Hansen <stefan.hansen at lisasoft.com>
> Para: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
> Enviadas: Quinta-feira, 27 de Agosto de 2009 9:21:36
> Assunto: [Live-demo] questions
> Hi!
> I just have some quick questions:
> Ricardo: You installed gvSIG into /home/user. Can I move it somewhere
> Some install-scripts (udig and grass so far) install sample data. For
> last years DVD we had some additional data sets. Most of them were
> loaded into Postgres. Do we want to do that again this year?
> cheers,
> stefan
> Stefan Hansen
> Software Engineer
> LISAsoft
> Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
> Level 9, 601 Bourke St, Melbourne Vic 3000
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> ____________________________________________________________________________________
> Veja quais são os assuntos do momento no Yahoo! +Buscados
> http://br.maisbuscados.yahoo.com
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
More information about the Live-demo
