[Live-demo] Re: Getting GeoNetwork on the Live DVD being handed out at the FOSS4G conference - unclassified
Ricardo Pinho rpinho_eng at yahoo.com.br
Mon Sep 7 18:05:06 EDT 2009
Thank you Byron for your collaboration.
I will see your tips about this alternative installation of GeoNetwork. But seems that it won't be possible to include it in time for feature freeze!
I would like to ask Simon for more help on including in the script the document installation:
https://sourceforge.net/projects/geonetwork/files/Documentation/GeoNetwork_opensource_v240_Manual.pdf/download
And to check and complete the GeoNetwork entry on this apps table:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Packages
Thank you,
Ricardo Pinho
http://gisvm.com
----- Mensagem original ----
De: Byron Cochrane <cochranes4 at eml.cc>
Para: rpinho_eng at yahoo.com.br; Simon.Pigot at csiro.au; live-demo at lists.osgeo.org; cameron.shorter at lisasoft.com
Enviadas: Domingo, 6 de Setembro de 2009 23:49:48
Assunto: RE: Getting GeoNetwork on the Live DVD being handed out at the FOSS4G conference - unclassified
Good Morning,
Sorry I missed this email string but it came to my work email and I was
out of the office by the time started.  (The benefit of being in a
different time zone.)  Anyway, is it sorted, or do you still need some
help?  I would defer to Simon on most questions - as he as a better
overall understanding of GN than do I, but I am willing to help out
where
I can.
It would be possible to design the install to
access other software installs on the VM like GeoServer, PostgreSQL, and
Tomcat, but I am not sure how much you would want to complicate the
install and deviate too much from the standard install. On the other
hand, multiple servlet engines, databases, and GeoServer installs could
be confusing and potentially conflicting on the VM and/or to the user as
well.
Here are some examples of how I configured my GeoNetwork2.2 setup:
If you want to run GN from Tomcat instead of jetty, just put your
version of the following in Tomcat/conf/server.xml :
                <Context
                path="/geonetwork"
                docBase="C:\Program Files\geonetwork22\web\geonetwork"
                crossContext="false"
                debug="1"
                reloadable="false" />
                <Context
                path="/intermap"
                docBase="C:\Program Files\geonetwork22\web\intermap"
                debug="1"
                <Context
                path="/geonetwork/intermap"
                debug="1"
                <Context
                path="/geoserver"
                docBase="C:\Program Files\geonetwork22\web\geoserver"
                debug="1"
                <Context
                path="/geonetwork/docs"
                docBase="C:\Program Files\geonetwork22\docs"
                debug="1"
If run from Tomcat, there is no need for the GN Start or Stop options in
the GN menu.
The GeoServer context could be a problem as it could conflict with other
GeoServer installs. Which begs the question, why not then point to the
other GeoServer install?  I have not got around to playing with this
yet. My assumption has been that a different GS install would only need
the named service to work with a different map service.  The file that
would configure the default Mapservice is
geonetwork/web/intermap/WEB-INF/mapServers.xml. The section that
configures default mapservices is <mapContexts). Here is what mine looks
like.  Presumably you can alter this to suit.
      <mapContexts>
                <default name="Layers for default map -- DUMMY NAME:not
                used">
                        <server
                        url="http://localhost:8080/geoserver/wms"
                        type="2" >
                                <layer name="gn:world"></layer>
                        </server>
                        <server
                        type="2" >
                                <layer name="gn:gboundaries"></layer>
                        </server>
<!--                    <server
url="http://www2.demis.nl/mapserver/request.asp"  type="2" >
                                <layer name="Topography"></layer>
                        </server>
                        <server
                         type="2" >
                                <layer name="Borders"></layer>
                        </server>
                        <server
                         type="2" >
                                <layer name="Coastlines"></layer>
                        </server>
                        <server
                        url="http://geonetwork3.fao.org/ows/12279"
                        type="2">
                                <layer name="world_country_boundary" />
                        </server>
                        <server url="http://geonetwork3.fao.org/ows/1"
                        type="2">
                                <layer name="national_boundaries_africa"
                        </server>
                </default>
The configuration file that controls the database being used is
geonetwork/web/geonetwork/WEB-INF/config.xml.  The tag where this is set
is <resources>.  I use postgresql and my config.xml file looks like
this:
<resources>
                <!-- Postgresql -->
                <resource enabled="true">
                        <name>main-db</name>
                        <provider>jeeves.resources.dbms.DbmsPool</provider>
                        <config>
                                <user>postgres</user>
                                <password>*******</password>
                                <driver>org.postgresql.Driver</driver>
                                <url>jdbc:postgresql://localhost:5432/geonetwork22</url>
                                <poolSize>10</poolSize>
                        </config>
                </resource>
The database would need to be configured first for this to work.  This
is easiest to do using GAST.
Hope this helps.  Let me know how it goes.
For future correspondence, it is probably best use this email.  To much
stuff gets blocked by my work email and I cannot access it outside work.
Simon, The last emails you sent me were blocked. Can you resend them to
this address?
Cheers,
Byron Cochrane
> -----Original Message-----
> From: Ricardo Pinho [mailto:rpinho_eng at yahoo.com.br]
> Sent: Sunday, 6 September 2009 8:51 p.m.
> To: Simon.Pigot at csiro.au; live-demo at lists.osgeo.org
> Cc: COCHRANE BYRON, MR; cameron.shorter at lisasoft.com
> Subject: Re: Getting GeoNetwork on the Live DVD being handed out at the
> FOSS4G conference
> Hi Simon,
> And thank you!
> I've just SVN commit to the trunk! (and put your name on it!)
> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/
> > 1. If looking to reduce footprint then don't install geoserver
> Let it be there for the time being! It' the official installation...
> We could probably make a install_geoserver_light.sh...  ;-)
> > 2. Advise people to change system config to port 8880
> Yes, thats a big problem!
> I've tried, two months ago, to install Geoserver on Tomcat and
> PostgreSQL. But didn't had time and skills to conclude it.
> http://gisvm.com/forum/index.php?topic=47.0
> I think installing Geoserver over tomcat can be a smarter solution for
> this VM!
> Could you please help me on this?
> > 3. cp jetty.xml $GEONETWORK_FOLDER/bin
> Of course, my mistake! (the problem of doing things at 1:00AM after a
> working day!)
> > Finally, I assume the choice of /usr/lib for install is because you are using a VM image for all this stuff?
> > but this is really just me being a UNIX purist (offends my dignity
> > even though this is a VM :-))
> LOL...
> I'm just trying to follow the rules made for this project:
> http://wiki.osgeo.org/wiki/GISVM_Build#Directory_Structure
> I really never understood where to put things on linux!!!
> As a windows purist, I prefer to put all the stuff on the Desktop...
> heheh, just joking!
> Well, as long as it works, it's alright for me (and for the user)!
> Cheers,
> Ricardo Pinho
> http://gisvm.com
> De: "Simon.Pigot at csiro.au" <Simon.Pigot at csiro.au>
> Para: Simon.Pigot at csiro.au; rpinho_eng at yahoo.com.br;
> Cc: byron.cochrane at nzdf.mil.nz; cameron.shorter at lisasoft.com
> Enviadas: Sábado, 5 de Setembro de 2009 16:53:14
> FOSS4G conference
> Hi Ricardo,
> Attached are desktop properties files that will start & stop the
> geonetwork server and crank up firefox (which I'm assuming is on your VM
> image) with GN open in it and a modified installer script to get these
> things and put them in the right place.
> Works locally here - however this took a lot longer than it should have
> since there was a Ubuntu bug which caused the desktop icons to fail
> intermittently if you requested a Terminal to see the output....grrrr
> Cheers,
> Simon
> _______________________________________
> From: Pigot, Simon (CMAR, Hobart)
> Sent: Sunday, 6 September 2009 12:04 AM
> To: Ricardo Pinho; live-demo at lists.osgeo.org
> Cc: byron.cochrane at nzdf.mil.nz; Cameron Shorter
> Subject: RE: Getting GeoNetwork on the Live DVD being handed out at the
> FOSS4G conference
> Hi Ricardo,
> Looks good. Yes admin/admin is default GN admin user and password. A few
> things I'd change maybe:
> 1. If looking to reduce footprint then don't install geoserver (remove
> <pack index="2"> from <selected> element in
> <com.izforge.izpack.panels.PacksPanel> element in install.xml) - GN still
> functions without it (brings in web map stuff from demis.nl etc instead
> of using the bluemarble stuff from its own geoserver).
> (Administration->System Configuration menu) after they start GN up
> otherwise GN will build incorrect URLs for things like file downloads
> using its default port of 8080.
> needs to be added to the install_geonetwork.sh script to make sure that
> the installed GN starts up on port 8880 rather than 8080.
> using a VM image for all this stuff? Even so, its not really the place
> that I'd go looking for 3rd party software (why not /usr/local?) but this
> is really just me being a UNIX purist (offends my dignity even though
> this is a VM :-)) - but this doesn't really matter :-)
> Cheers, thanks and good work!
> Simon
> ________________________________________
> From: Ricardo Pinho [rpinho_eng at yahoo.com.br]
> Sent: Saturday, 5 September 2009 6:23 PM
> To: Pigot, Simon (CMAR, Hobart); live-demo at lists.osgeo.org
> FOSS4G conference
> Hi Simon,
> I've made a first draft of a "install_geonetwork.sh"
> Along with some config files:
> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/geonetwork-conf/
> This is based on Geonetwork official install jar application.
> So it uses Jetty, Geoserver and McKoy.
> I haven't change the heap memory on the start_geoserver.sh (java -Xms48m
> -Xmx512m -Xss2M -XX:MaxPermSize=128m) But we can eventually change  it.
> The script still lacks creating a Desktop/Menu start/stop link/icon so
> users can easily start/stop geonetwork.
> Please give it a look and help us improve the install script and test it.
> I'm not a geonetwork user... :-(
> And please confirm this:
> The default geonetwork user is:
> login = admin
> passw = admin
> Cheers,
> Ricardo Pinho
> http://gisvm.com
> De: Cameron Shorter <cameron.shorter at lisasoft.com>
> Para: "Simon.Pigot at csiro.au" <Simon.Pigot at csiro.au>
> Cc: "byron.cochrane at nzdf.mil.nz" <byron.cochrane at nzdf.mil.nz>;
> "rpinho_eng at yahoo.com.br" <rpinho_eng at yahoo.com.br>
> Enviadas: Sexta-feira, 4 de Setembro de 2009 8:40:26
> Assunto: Re: Getting GeoNetwork on the Live DVD being handed out at the
> FOSS4G conference
> Simon,
> As the LiveDVD is memory poor, we aim to have applications set up one at
> a time.
> I didn't realise that GeoNetwork also includes GeoServer. That would
> likely be the reason it uses up more memory.
> Ricardo, I'm interested to know how much memory is being used.
> Richardo should be able to tell is the details.
> Simon.Pigot at csiro.au wrote:
> > Hi Cameron and Ricardo,
> > Happy to help - let me know what you need.
> > Just a point of clarification Cameron: I assume the problem 'with footprint' is the fact that GN is using Jetty and everything else is using Tomcat? Or would you like to remove the Geoserver part of GeoNetwork as well?
> > Cheers,
> > Simon
> > From: Cameron Shorter [cameron.shorter at lisasoft.com]
> > Sent: Friday, 4 September 2009 3:10 PM
> > To: Byron Cochrane
> > Cc: Pigot, Simon (CMAR, Hobart); Ricardo Pinho
> > Subject: Getting GeoNetwork on the Live DVD being handed out at the
> > FOSS4G conference
> > Simon, Byron, (Geonetwork coding wizards)
> > We are putting together a Xubuntu based Live DVD which will be handed
> > out to all delegates at the upcoming Free and Open Source Software for
> > Geopatial conference, coming to Sydney in October.
> > http://2009.foss4g.org
> > So far, we have a full stack of most of the key Open Source Geospatial
> > applications on the LiveDVD, and Ricardo has made a brave crack at
> > getting GeoNetwork onto the LiveDVD, but is asking for help. (Ricardo
> > is more a GIS user than a programmer)
> > The process for getting an application onto the LiveDVD is to write a
> > shell install script, as per:
> > I understand that Ricardo has this mostly working, but needs some
> > help, in particular in trying to reduce the footprint of GeoNetwork so
> > that it can run on the memory limited virtual machine or LiveDVD.
> > Ricardo should be able to provide more details about where his script
> > is, and what help he is looking for.
> > Byron, Simon,
> > Is it ok if Ricardo can ask you questions, and if you could review his
> > install script which I understand he will be putting into svn within
> > the next 24 hours.
> > Cameron Shorter
> > Geospatial Systems Architect
> > Tel: +61 (0)2 8570 5050
> > Mob: +61 (0)419 142 254
> > Think Globally, Fix Locally
> > Geospatial Solutions enhanced with Open Standards and Open Source
> > http://www.lisasoft.com
> Cameron Shorter
>       ____________________________________________________________________________________
> Veja quais são os assuntos do momento no Yahoo! +Buscados
> http://br.maisbuscados.yahoo.com
> The information contained in this Internet Email message is intended
> for the addressee only and may contain privileged information, but not
> necessarily the official views or opinions of the New Zealand Defence
> Force.
> If you are not the intended recipient you must not use, disclose, copy or
> distribute this message or the information in it.
> If you have received this message in error, please Email or telephone
> the sender immediately.
  Byron Cochrane
More information about the Live-demo mailing list
