[Live-demo] GeoKettle on alpha5
Cameron Shorter
cameron.shorter at gmail.com
Wed Sep 16 16:17:33 EDT 2009
Thanks Etienne,
If you have not done so already, can you please update your install
script header with a comment about what versions of java geokettle will
run with, and which you would prefer (if any). This will be useful for
future packagers.
Etienne Dube wrote:
> I downloaded alpha5 and tested GeoKettle, everything seems fine. Also
> installed sun-java5-bin and tried it under this version just to make
> sure. Either java 5 or 6 will work with GeoKettle.
> I will update the text description and test steps today.
> Etienne
> Cameron Shorter a écrit :
>> The latest alpha5 LiveDVD is available for download. Please download
>> and check your applications run as you would expect, and adjust any
>> scripts as required.
>> With this latest build of the Live DVD, I've kept install logs, and
>> also checked disk size after each package install, so you can get an
>> indication about how much space each application uses. (Note that
>> this also includes the tmp/ download directory which is not deleted
>> during the download).
>> The latest image, and logs are available at:
>> http://download.osgeo.org/livedvd/
>> <http://download.osgeo.org/livedvd/ArramagongGISVM2009alpha4.7z.1>
>> Next:
>> By COB this Wednesday 16 Sept:
>> * Test your application, make sure it works. Adjust your scripts if
>> required. Report back to this email list that your application has
>> been tested and works (or doesn't).
>> * We need a text description of your project to put into the
>> documentation, as per:
>> http://wiki.osgeo.org/wiki/GISVM_Build#Writing_docs
>> * Ensure that test steps for your project are defined at:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing
>> It should contain enough information for an Ubuntu user who is
>> unfamiliar an application to try it out and confirm that everything
>> has been installed correctly.''
>> * Java projects, please provide guidance on what version of Java we
>> should ship - whether we should use Tomcat, Jetty, or something else.
>> It seems we have a number of projects installing their own JRE.
>> Thursday 17 Sept:
>> * Release 2.0 RC 1 of virtual machine. Ask foss4g delegates to try
>> out the DVD and report any errors they find. (This will be a major
>> FOSS4G press release).
>> * I hope to also have an ISO of the live DVD created from this image
>> as well.
>> * Developers, please ensure the metrics like version number and
>> contact person are up to date at:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Packages
>> Final release:
>> At the moment, deadline for final build to meet our printing
>> deadline is Sunday 20 September, in 1 week. I hope to be able to get
>> an extra week for testing. I'm still negotiating on this, so please
>> do get everything working and tested this week.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
