[Live-demo] GeoKettle on alpha5
Etienne Dube
etdube at gmail.com
Wed Sep 16 16:57:46 EDT 2009
Hi Cameron,
Done (GeoKettle runs fine on either 5 or 6, no specific preference;
future versions may eventually rely on Java 6 features though). I also
completed the text description.
Thanks for all your work,
Etienne
Cameron Shorter a écrit :
> Thanks Etienne,
> If you have not done so already, can you please update your install
> script header with a comment about what versions of java geokettle
> will run with, and which you would prefer (if any). This will be
> useful for future packagers.
> Etienne Dube wrote:
>> I downloaded alpha5 and tested GeoKettle, everything seems fine. Also
>> installed sun-java5-bin and tried it under this version just to make
>> sure. Either java 5 or 6 will work with GeoKettle.
>> I will update the text description and test steps today.
>> Etienne
>>> The latest alpha5 LiveDVD is available for download. Please download
>>> and check your applications run as you would expect, and adjust any
>>> scripts as required.
>>> With this latest build of the Live DVD, I've kept install logs, and
>>> also checked disk size after each package install, so you can get an
>>> indication about how much space each application uses. (Note that
>>> this also includes the tmp/ download directory which is not deleted
>>> during the download).
>>> The latest image, and logs are available at:
>>> http://download.osgeo.org/livedvd/
>>> <http://download.osgeo.org/livedvd/ArramagongGISVM2009alpha4.7z.1>
>>> Next:
>>> By COB this Wednesday 16 Sept:
>>> * Test your application, make sure it works. Adjust your scripts if
>>> required. Report back to this email list that your application has
>>> been tested and works (or doesn't).
>>> * We need a text description of your project to put into the
>>> documentation, as per:
>>> http://wiki.osgeo.org/wiki/GISVM_Build#Writing_docs
>>> * Ensure that test steps for your project are defined at:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing
>>> It should contain enough information for an Ubuntu user who is
>>> unfamiliar an application to try it out and confirm that everything
>>> has been installed correctly.''
>>> * Java projects, please provide guidance on what version of Java we
>>> should ship - whether we should use Tomcat, Jetty, or something
>>> else. It seems we have a number of projects installing their own JRE.
>>> Thursday 17 Sept:
>>> * Release 2.0 RC 1 of virtual machine. Ask foss4g delegates to try
>>> out the DVD and report any errors they find. (This will be a major
>>> FOSS4G press release).
>>> * I hope to also have an ISO of the live DVD created from this image
>>> as well.
>>> * Developers, please ensure the metrics like version number and
>>> contact person are up to date at:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Packages
>>> Final release:
>>> At the moment, deadline for final build to meet our printing
>>> deadline is Sunday 20 September, in 1 week. I hope to be able to get
>>> an extra week for testing. I'm still negotiating on this, so please
>>> do get everything working and tested this week.
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo
