[Live-demo] load_postgis.sh wrong data url.
Massimo Di Stefano
massimodisasha at yahoo.it
Fri Sep 25 21:27:21 EDT 2009
Hi, in the script load_postgis.sh
there is a not found url to the data.
ftp://ftp.ardec.com.au/UPLOADS/medford-gisvm.sql.bz2
is this the new url to the data :
ftp://ftp.ardec.com.au/UPLOADS/postgis_data.zip
if it is the right dataset, do you know if the sed command is no
longer required?
thanks.
Massimo.
p.s.
loading the postgis layer inside qgis i had a worning, maiby not all
the layer are loaded
but not sure about it.
More information about the Live-demo
