[Live-demo] load_postgis.sh wrong data url.
Hamish hamish_b at yahoo.com
Sat Sep 26 01:28:23 EDT 2009
Massimo wrote:
> Hi, in the script
> load_postgis.sh
> there is a not found url to the data.
> ftp://ftp.ardec.com.au/UPLOADS/medford-gisvm.sql.bz2
> is this the new url to the data :
> ftp://ftp.ardec.com.au/UPLOADS/postgis_data.zip
(if you rename stuff please leave behind symlinks)
> if it is the right dataset, do you know if the sed command
> is no longer required?
also I notice that load_postgis.sh is not called by main.sh
or anything else, so is not currently run loaded.
Hamish
ps- back to postgis 1.3 in svn. the build of 1.4 looks ok; with-
out a 'make install' file list I tried to make one-> it will
need patch to rename conflicting installed file names before
further consideration.
More information about the Live-demo mailing list
