[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live DVD before we burn it
Massimo Di Stefano massimodisasha at gmail.com
Thu Aug 5 17:42:11 EDT 2010
hi Cameron,
seems i find a solution,
i build the software locally on a fresh xubuntu and i stored all the build in a directory (150 mb)
i tried it on the live-gis VM and it works as aspected (it only need the LD_LIBRARY_PATH to be setted)
tell me i can i add a replacement of install_ossim.sh to try thi procedure unless a new debian packages will ready.
Il giorno 05/ago/2010, alle ore 23.01, Cameron Shorter ha scritto:
> Thanks for trying to track down this issue Massimo asap.
> I understand that Alex will be cutting a final release candidate, which will hopefully become the final release this Monday 9 Aug. If you fix the issue, we can verify it works, and hasn't effected any other packages on that release.
> On 05/08/10 18:38, Massimo Di Stefano wrote:
>> Hi All,
>> from the osgeo live list :
>> Inizio messaggio inoltrato:
>>>> The OSGeo-Live DVD is looking great, with 43 pre-configured GeoSpatial
>>>> Open Source packages and marketing documentation.
>>>> It will be sent to the printers next week, Monday 9 August, and we are
>>>> calling on all projects to test their applications and documentation
>>>> and verify everything is working fine.
>>>> Could everyone with an interest please:
>>>> download an ISO or Virtual Machine from here:
>>>> http://download.osgeo.org/livedvd/4.0-rc6/
>>>> run (and update) test steps for your project. Test steps might be "Run
>>>> steps in QuickStart". Record results here:
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing
>>>> review documentation:
>>>> http://download.osgeo.org/livedvd/4.0-rc6/osgeolive-docs/index.html
>>>> if inspired - write a quickstart, or add screen shots to an existing quickstart.
>>>> fix anything that is broken
>> Ossim is present on the live-dvd thanks to the ubuntu packages prepared by Pirimin K.
>> testing it i can see Imagelinker is built using ossim_qt4 instead of qt3, this give us a non-full working imagelinker :-(
>> right now i'm preparing a fresh VM on which i'll try to rebuild imagelinker and ossimplanet from svn,
>> unlucky i have no experience building .deb ...
>> maybe using a cmake build "out of source" i can try to build a "static version" for all the ossim suite.
>> here my question :
>> using cmake i'm able to choose wich part of ossim i should build
>> but i can't find an entry to choose between ossim_qt or ossim_qt4
>> i can see only ossim_qt4 [ON/OFF]
>> Pirimin, have you time/resource to build a new packages .deb ?
>> Please, i'm avaiable at any time to try to generate a new .deb
>> thanks to anyone who has experience on this side.
>> Ciao,
>> Massimo.
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100805/8070a799/attachment.html
More information about the Live-demo mailing list
