[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live
DVD before we burn it
Cameron Shorter
cameron.shorter at gmail.com
Thu Aug 5 18:25:53 EDT 2010
Massimo,
If your fix is not expected to effect any other application, then please
apply your fix.
If another application might be effected, could you please discuss this
on the list first, before we make a decision either way.
On 06/08/10 07:42, Massimo Di Stefano wrote:
> hi Cameron,
> seems i find a solution,
> i build the software locally on a fresh xubuntu and i stored all the
> build in a directory (150 mb)
> i tried it on the live-gis VM and it works as aspected (it only need
> the LD_LIBRARY_PATH to be setted)
> tell me i can i add a replacement of install_ossim.sh to try thi
> procedure unless a new debian packages will ready.
> Il giorno 05/ago/2010, alle ore 23.01, Cameron Shorter ha scritto:
>> Thanks for trying to track down this issue Massimo asap.
>> I understand that Alex will be cutting a final release candidate,
>> which will hopefully become the final release this Monday 9 Aug. If
>> you fix the issue, we can verify it works, and hasn't effected any
>> other packages on that release.
>> On 05/08/10 18:38, Massimo Di Stefano wrote:
>>> Hi All,
>>> from the osgeo live list :
>>> Inizio messaggio inoltrato:
>>>>> The OSGeo-Live DVD is looking great, with 43 pre-configured GeoSpatial
>>>>> Open Source packages and marketing documentation.
>>>>> It will be sent to the printers next week, Monday 9 August, and we are
>>>>> calling on all projects to test their applications and documentation
>>>>> and verify everything is working fine.
>>>>> Could everyone with an interest please:
>>>>> download an ISO or Virtual Machine from here:
>>>>> http://download.osgeo.org/livedvd/4.0-rc6/
>>>>> run (and update) test steps for your project. Test steps might be "Run
>>>>> steps in QuickStart". Record results here:
>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing
>>>>> review documentation:
>>>>> http://download.osgeo.org/livedvd/4.0-rc6/osgeolive-docs/index.html
>>>>> if inspired - write a quickstart, or add screen shots to an
>>>>> existing quickstart.
>>>>> fix anything that is broken
>>> Ossim is present on the live-dvd thanks to the ubuntu packages
>>> prepared by Pirimin K.
>>> testing it i can see Imagelinker is built using ossim_qt4 instead of
>>> qt3, this give us a non-full working imagelinker :-(
>>> right now i'm preparing a fresh VM on which i'll try to rebuild
>>> imagelinker and ossimplanet from svn,
>>> unlucky i have no experience building .deb ...
>>> maybe using a cmake build "out of source" i can try to build a
>>> "static version" for all the ossim suite.
>>> here my question :
>>> using cmake i'm able to choose wich part of ossim i should build
>>> but i can't find an entry to choose between ossim_qt or ossim_qt4
>>> i can see only ossim_qt4 [ON/OFF]
>>> Pirimin, have you time/resource to build a new packages .deb ?
>>> Please, i'm avaiable at any time to try to generate a new .deb
>>> thanks to anyone who has experience on this side.
>>> Ciao,
>>> Massimo.
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
>> Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
Cameron Shorter
Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100806/83791a55/attachment-0001.html
More information about the Live-demo
