[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live
DVD before we burn it
Massimo Di Stefano
massimodisasha at gmail.com
Fri Aug 6 22:34:02 EDT 2010
Il giorno 06/ago/2010, alle ore 22.40, Cameron Shorter ha scritto:
> Massimo,
> In order to decide whether to recommend using the new install_ossim2.sh or not, I'd like you to explain briefly:
> 1. Is it possible/likely that this update will effect any other application? If so, which applications? Have you tested these applications after the updated script has been run?
i've tested it on a local VM, all goes ok.
looking at the script see what it does, it can't break anything
> 2. How beneficial is the upgrade to ossim? Note, it seems that the OSSIM tests have failed. Could you please look into this asap too:
> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing#ossim
i tried to run all the build script using the updated instyall_ossim2.sh, ossim tests seems to works fine
i gived a look at the test results ... seems 80% of the failure are about "data not found or data can't be load"
that's weird seems on the iso used to test the install data script don't works as aspected ?!
i'm starting right now a fresh build using the latest script to see what happens
> On 07/08/10 02:10, Massimo Di Stefano wrote:
>> Hi added a new script inside the bin directory : install_ossim2.sh
>> it install a locally build version for ossim (last svn checkout) and fix a bug in imagelinker application (using qt3 instead of qt4)
>> tell me if i can replace the script in the main.sh so we can see if it's all ok
>> (i tested it locally and it should work)
>> Hamish :-) i'm sure the script will benefit from your eyes :-)
>> p.s.
>> in the tarbal is also included a "full" GPSTK [1] installation.
>> it is needed by OSSIM as dependencie,
>> i can cut it including only libs and headers (save 70 mb) but i prefer to leave it untouched.
>> GPSTK is a great piece of sw, having it on the live is cool, if you agree i can write documentation for it too
>> [1] http://www.gpstk.org/bin/view/Documentation/WebHome
>> Il giorno 06/ago/2010, alle ore 00.25, Cameron Shorter ha scritto:
>>> Massimo,
>>> If your fix is not expected to effect any other application, then please apply your fix.
>>> If another application might be effected, could you please discuss this on the list first, before we make a decision either way.
>>> On 06/08/10 07:42, Massimo Di Stefano wrote:
>>>> hi Cameron,
>>>> seems i find a solution,
>>>> i build the software locally on a fresh xubuntu and i stored all the build in a directory (150 mb)
>>>> i tried it on the live-gis VM and it works as aspected (it only need the LD_LIBRARY_PATH to be setted)
>>>> tell me i can i add a replacement of install_ossim.sh to try thi procedure unless a new debian packages will ready.
>>>> Il giorno 05/ago/2010, alle ore 23.01, Cameron Shorter ha scritto:
>>>>> Thanks for trying to track down this issue Massimo asap.
>>>>> I understand that Alex will be cutting a final release candidate, which will hopefully become the final release this Monday 9 Aug. If you fix the issue, we can verify it works, and hasn't effected any other packages on that release.
>>>>> On 05/08/10 18:38, Massimo Di Stefano wrote:
>>>>>> Hi All,
>>>>>> from the osgeo live list :
>>>>>> Inizio messaggio inoltrato:
>>>>>>>> The OSGeo-Live DVD is looking great, with 43 pre-configured GeoSpatial
>>>>>>>> Open Source packages and marketing documentation.
>>>>>>>> It will be sent to the printers next week, Monday 9 August, and we are
>>>>>>>> calling on all projects to test their applications and documentation
>>>>>>>> and verify everything is working fine.
>>>>>>>> Could everyone with an interest please:
>>>>>>>> download an ISO or Virtual Machine from here:
>>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/
>>>>>>>> run (and update) test steps for your project. Test steps might be "Run
>>>>>>>> steps in QuickStart". Record results here:
>>>>>>>> review documentation:
>>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/osgeolive-docs/index.html
>>>>>>>> if inspired - write a quickstart, or add screen shots to an existing quickstart.
>>>>>>>> fix anything that is broken
>>>>>> Ossim is present on the live-dvd thanks to the ubuntu packages prepared by Pirimin K.
>>>>>> testing it i can see Imagelinker is built using ossim_qt4 instead of qt3, this give us a non-full working imagelinker :-(
>>>>>> right now i'm preparing a fresh VM on which i'll try to rebuild imagelinker and ossimplanet from svn,
>>>>>> unlucky i have no experience building .deb ...
>>>>>> maybe using a cmake build "out of source" i can try to build a "static version" for all the ossim suite.
>>>>>> here my question :
>>>>>> using cmake i'm able to choose wich part of ossim i should build
>>>>>> but i can't find an entry to choose between ossim_qt or ossim_qt4
>>>>>> i can see only ossim_qt4 [ON/OFF]
>>>>>> Pirimin, have you time/resource to build a new packages .deb ?
>>>>>> Please, i'm avaiable at any time to try to generate a new .deb
>>>>>> thanks to anyone who has experience on this side.
>>>>>> Ciao,
>>>>>> Massimo.
>>>>>> _______________________________________________
>>>>>> Live-demo mailing list
>>>>>> Live-demo at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>> Cameron Shorter
>>>>> Geospatial Director
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
>>> Cameron Shorter
>>> Geospatial Director
> Cameron Shorter
> Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100807/0f4ad4a9/attachment.html
More information about the Live-demo
