[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live
DVD before we burn it
Cameron Shorter
cameron.shorter at gmail.com
Fri Aug 6 23:57:06 EDT 2010
Massimo,
Based on your note that the changes in your script will not effect any
other applications, go ahead and update the install_ossim.sh script.
On 07/08/10 12:34, Massimo Di Stefano wrote:
> Hi,
> Il giorno 06/ago/2010, alle ore 22.40, Cameron Shorter ha scritto:
>> Massimo,
>> In order to decide whether to recommend using the new
>> install_ossim2.sh or not, I'd like you to explain briefly:
>> 1. Is it possible/likely that this update will effect any other
>> application? If so, which applications? Have you tested these
>> applications after the updated script has been run?
> i've tested it on a local VM, all goes ok.
> looking at the script see what it does, it can't break anything
>> 2. How beneficial is the upgrade to ossim? Note, it seems that the
>> OSSIM tests have failed. Could you please look into this asap too:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing#ossim
> i tried to run all the build script using the updated
> instyall_ossim2.sh, ossim tests seems to works fine
> i gived a look at the test results ... seems 80% of the failure are
> about "data not found or data can't be load"
> that's weird seems on the iso used to test the install data script
> don't works as aspected ?!
> i'm starting right now a fresh build using the latest script to see
> what happens
>> On 07/08/10 02:10, Massimo Di Stefano wrote:
>>> Hi added a new script inside the bin directory : install_ossim2.sh
>>> it install a locally build version for ossim (last svn checkout) and
>>> fix a bug in imagelinker application (using qt3 instead of qt4)
>>> tell me if i can replace the script in the main.sh so we can see if
>>> it's all ok
>>> (i tested it locally and it should work)
>>> Hamish :-) i'm sure the script will benefit from your eyes :-)
>>> p.s.
>>> in the tarbal is also included a "full" GPSTK [1] installation.
>>> it is needed by OSSIM as dependencie,
>>> i can cut it including only libs and headers (save 70 mb) but i
>>> prefer to leave it untouched.
>>> GPSTK is a great piece of sw, having it on the live is cool, if you
>>> agree i can write documentation for it too
>>> [1] http://www.gpstk.org/bin/view/Documentation/WebHome
>>> Il giorno 06/ago/2010, alle ore 00.25, Cameron Shorter ha scritto:
>>>> Massimo,
>>>> If your fix is not expected to effect any other application, then
>>>> please apply your fix.
>>>> If another application might be effected, could you please discuss
>>>> this on the list first, before we make a decision either way.
>>>> On 06/08/10 07:42, Massimo Di Stefano wrote:
>>>>> hi Cameron,
>>>>> seems i find a solution,
>>>>> i build the software locally on a fresh xubuntu and i stored all
>>>>> the build in a directory (150 mb)
>>>>> i tried it on the live-gis VM and it works as aspected (it only
>>>>> need the LD_LIBRARY_PATH to be setted)
>>>>> tell me i can i add a replacement of install_ossim.sh to try thi
>>>>> procedure unless a new debian packages will ready.
>>>>> Il giorno 05/ago/2010, alle ore 23.01, Cameron Shorter ha scritto:
>>>>>> Thanks for trying to track down this issue Massimo asap.
>>>>>> I understand that Alex will be cutting a final release candidate,
>>>>>> which will hopefully become the final release this Monday 9 Aug.
>>>>>> If you fix the issue, we can verify it works, and hasn't effected
>>>>>> any other packages on that release.
>>>>>> On 05/08/10 18:38, Massimo Di Stefano wrote:
>>>>>>> Hi All,
>>>>>>> from the osgeo live list :
>>>>>>> Inizio messaggio inoltrato:
>>>>>>>>> The OSGeo-Live DVD is looking great, with 43 pre-configured
>>>>>>>>> GeoSpatial
>>>>>>>>> Open Source packages and marketing documentation.
>>>>>>>>> It will be sent to the printers next week, Monday 9 August,
>>>>>>>>> and we are
>>>>>>>>> calling on all projects to test their applications and
>>>>>>>>> documentation
>>>>>>>>> and verify everything is working fine.
>>>>>>>>> Could everyone with an interest please:
>>>>>>>>> download an ISO or Virtual Machine from here:
>>>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/
>>>>>>>>> run (and update) test steps for your project. Test steps might
>>>>>>>>> be "Run
>>>>>>>>> steps in QuickStart". Record results here:
>>>>>>>>> review documentation:
>>>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/osgeolive-docs/index.html
>>>>>>>>> if inspired - write a quickstart, or add screen shots to an
>>>>>>>>> existing quickstart.
>>>>>>>>> fix anything that is broken
>>>>>>> Ossim is present on the live-dvd thanks to the ubuntu packages
>>>>>>> prepared by Pirimin K.
>>>>>>> testing it i can see Imagelinker is built using ossim_qt4
>>>>>>> instead of qt3, this give us a non-full working imagelinker :-(
>>>>>>> right now i'm preparing a fresh VM on which i'll try to rebuild
>>>>>>> imagelinker and ossimplanet from svn,
>>>>>>> unlucky i have no experience building .deb ...
>>>>>>> maybe using a cmake build "out of source" i can try to build a
>>>>>>> "static version" for all the ossim suite.
>>>>>>> here my question :
>>>>>>> using cmake i'm able to choose wich part of ossim i should build
>>>>>>> but i can't find an entry to choose between ossim_qt or ossim_qt4
>>>>>>> i can see only ossim_qt4 [ON/OFF]
>>>>>>> Pirimin, have you time/resource to build a new packages .deb ?
>>>>>>> Please, i'm avaiable at any time to try to generate a new .deb
>>>>>>> thanks to anyone who has experience on this side.
>>>>>>> Ciao,
>>>>>>> Massimo.
>>>>>>> _______________________________________________
>>>>>>> Live-demo mailing list
>>>>>>> Live-demo at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>> Cameron Shorter
>>>>>> Geospatial Director
>>>>>> Tel: +61 (0)2 8570 5050
>>>>>> Mob: +61 (0)419 142 254
>>>>>> Think Globally, Fix Locally
>>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>>> http://www.lisasoft.com
>>>>>> Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>>>> Cameron Shorter
>>>> Geospatial Director
>> Cameron Shorter
>> Geospatial Director
Cameron Shorter
Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100807/6c31b890/attachment-0001.html
More information about the Live-demo
