[Live-demo] 4.0 beta3 Online
Johan Van de Wauw
johan.vandewauw at gmail.com
Fri Jul 23 03:59:36 EDT 2010
Are there any problems with the live dvd run natively when the virtual
box helper tools are installed? Unless people oppose I can try to make
a test build this weekend with virtual box already installed and see
if there are issues when you run it natively.
Johan
On Fri, Jul 23, 2010 at 7:34 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> When running as a virtual machine you must install the toolbox for that
> software to get higher resolutions, see the bottom of live.osgeo.org for
> details.
> The final ISO as in Version 3 when run directly on a computer (boot from
> disk) has a much higher default resolution auto-detected from the monitor.
> As for the keyboard layout, alternate layouts are available at the login
> screen, and as a finishing touch which unfortunately must be done by
> hand we have been adding a keyboard switcher to the panel of the final
> product. Try out Version 3 to see what I'm talking about.
> Thanks,
> Alex
> On 07/22/2010 08:41 PM, Daniel Kastl wrote:
>> Hi list,
>> Not sure this is something that will be OK on the LiveDVD, but when I
>> started the latest beta in VirtualBox the screen resolution is 800x600 only
>> and with the graphical display manager I can't get more. I know that you can
>> change this by editing configuration files, but we can't expect that a
>> typical LiveDVD user (or my workshop participants) will be able to do this.
>> Very similar problem is the default keyboard. Lucky if you have a US
>> keyboard layout, but very often the first thing people have to change is the
>> keyboard layout. I suppose the Spanish keyboard is different as well. Any
>> idea how to make this easy for users?
>> Daniel
>> 2010/7/21 <maplabs at light42.com>
>>> change of language at login
>>> sounds exactly right to me..
>>> On Tue, 20 Jul 2010 14:04:50 -0700, Alex Mandel wrote:
>>> On 07/20/2010 01:01 PM, Hamish wrote:
>>> > > Alex wrote:
>>> > >>> Major quirk - in the mysql config in the Ushahidi
>>> > >>> scriptlines 67-70 that didn't go right this time,
>>> > >>> something funny about the mysql password and it prompted
>>> > >>> me because of it. > >
>>> > > hopefully fixed with r4054. mysql man page says:
>>> > > o --password[=password], -p[password]
>>> > > The password to use when connecting to the server. If
>>> > > you use the short option form (-p), you cannot have a
>>> > > space between the option and the password. If you omit
>>> > > the password value following the --password or -p
>>> > > option on the command line, you are prompted for one. > >
>>> > > so the extra space after -p meant that it was treating the
>>> > > password as the database name. > >
>>> > > Hamish
>>> > > ps- for desktop-conf/custom.conf any reason not to use the
>>> > > automatic login on startup?
>>> > > currently: AutomaticLoginEnable=false
>>> > > does that mean you can't get to gdm even if you log out?
>>> > Ah I didn't realize in the man page that meant you can't have a space.
>>> > I'd opt for the --password= to be more clear. >
>>> > I think it's good to allow people to change the language before login.
>>> > Also that delay before login may allow some services to finish coming up
>>> > so the experience once in should be better(guess). >
>>> > You should still be able to get to the login screen if you logout of a
>>> > session. Without seeing the login screen, not sure if users will be
>>> > aware of this option and that is where you change language/keyboard. >
>>> > Thanks,
>>> > Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
