[Live-demo] 4.0 beta3 Online
Alex Mandel tech_dev at wildintellect.com
Fri Jul 23 11:02:11 EDT 2010
I have tested this before and it works, the problem is when you want to
use vmware instead of virtual-box, though I don't think it causes a
problem on vmware to have the wrong tools. However to get the right
tools you must use the ubuntu repos so that they remove the vbox tools,
if someone tries to use the normal way which is the files supplied by
either set it wouldn't remove the other and that would cause a conflict,
possibly an unbootable vm.
There is a ticket/idea to have the disc choose which modules to load at
boot, we just never got around to figuring out how to do that.
Note the actual build happens on vmware right now. We could state a
preference for Vbox though since it has an open source version and
include it tools by default. No idea if this will effect people running
Parallels. Are the computers for the workshops going to have VirtualBox
or some VM software?
Thanks,
Alex
On 07/23/2010 12:59 AM, Johan Van de Wauw wrote:
> Are there any problems with the live dvd run natively when the virtual
> box helper tools are installed? Unless people oppose I can try to make
> a test build this weekend with virtual box already installed and see
> if there are issues when you run it natively.
> Johan
> On Fri, Jul 23, 2010 at 7:34 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> When running as a virtual machine you must install the toolbox for that
>> software to get higher resolutions, see the bottom of live.osgeo.org for
>> details.
>> The final ISO as in Version 3 when run directly on a computer (boot from
>> disk) has a much higher default resolution auto-detected from the monitor.
>> As for the keyboard layout, alternate layouts are available at the login
>> screen, and as a finishing touch which unfortunately must be done by
>> hand we have been adding a keyboard switcher to the panel of the final
>> product. Try out Version 3 to see what I'm talking about.
>> Thanks,
>> Alex
>> On 07/22/2010 08:41 PM, Daniel Kastl wrote:
>>> Hi list,
>>> Not sure this is something that will be OK on the LiveDVD, but when I
>>> started the latest beta in VirtualBox the screen resolution is 800x600 only
>>> and with the graphical display manager I can't get more. I know that you can
>>> change this by editing configuration files, but we can't expect that a
>>> typical LiveDVD user (or my workshop participants) will be able to do this.
>>> Very similar problem is the default keyboard. Lucky if you have a US
>>> keyboard layout, but very often the first thing people have to change is the
>>> keyboard layout. I suppose the Spanish keyboard is different as well. Any
>>> idea how to make this easy for users?
>>> Daniel
>>> 2010/7/21 <maplabs at light42.com>
>>>> change of language at login
>>>>  sounds exactly right to me..
>>>> On Tue, 20 Jul 2010 14:04:50 -0700, Alex Mandel  wrote:
>>>> On 07/20/2010 01:01 PM, Hamish wrote:
>>>>  > > Alex wrote:
>>>>  > >>> Major quirk - in the mysql config in the Ushahidi
>>>>  > >>> scriptlines 67-70 that didn't go right this time,
>>>>  > >>> something funny about the mysql password and it prompted
>>>>  > >>> me because of it.  > >
>>>>  > > hopefully fixed with r4054. mysql man page says:
>>>>  > >        o  --password[=password], -p[password]
>>>>  > >           The password to use when connecting to the server. If
>>>>  > >           you use the short option form (-p), you cannot have a
>>>>  > >           space between the option and the password. If you omit
>>>>  > >           the password value following the --password or -p
>>>>  > >           option on the command line, you are prompted for one.  > >
>>>>  > > so the extra space after -p meant that it was treating the
>>>>  > > password as the database name.  > >
>>>>  > > Hamish
>>>>  > > ps- for desktop-conf/custom.conf any reason not to use the
>>>>  > > automatic login on startup?
>>>>  > > currently:  AutomaticLoginEnable=false
>>>>  > > does that mean you can't get to gdm even if you log out?
>>>>  > Ah I didn't realize in the man page that meant you can't have a space.
>>>>  > I'd opt for the --password= to be more clear.  >
>>>>  > I think it's good to allow people to change the language before login.
>>>>  > Also that delay before login may allow some services to finish coming up
>>>>  > so the experience once in should be better(guess).  >
>>>>  > You should still be able to get to the login screen if you logout of a
>>>>  > session. Without seeing the login screen, not sure if users will be
>>>>  > aware of this option and that is where you change language/keyboard.  >
>>>>  > Thanks,
>>>>  > Alex
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
