[Live-demo] 4.0 rc5 build
Astrid Emde astrid_emde at osgeo.org
Wed Jul 28 17:38:18 EDT 2010
Hi Alex, hi list,
I removed the Mapbender Icon from the deskop and moved it to Navigation
and Maps.
I did this directly in the install_mapbender.sh
I have another question about the menu:
Mapbender only shows up in Applications - Education
It does not show up at Applications - Other (Andere in german), where all
the other applications show up. Do you know what I made wrong. Is there
another file where I should handle this?
This is what I did:
#Add Launch icon to desktop
if [ ! -e /usr/share/applications/mapbender.desktop ] ; then
   cat << EOF > /usr/share/applications/mapbender.desktop
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=Mapbender
Comment=Mapbender
Categories=Application;Geography;Geoscience;Education;
Exec=firefox http://localhost/mapbender/
Icon=/usr/share/icons/mapbender_desktop_48x48.png
Terminal=false
StartupNotify=false
EOF
fi
cp /usr/share/applications/mapbender.desktop
"$USER_HOME/Desktop/Navigation and Maps"
Astrid
On Wed, July 28, 2010 6:09 am, Alex Mandel wrote:
> On 07/27/2010 10:30 PM, Hamish wrote:
>> Alex wrote:
>>> The Help Launcher is nowhere to be seen, the files are there the logs
>>>  seem ok, maybe the icon shuffle at the end did it in(I looked but
>>> didn't see it in any of the folders)?
>> ok; will have to investigate later.
>>> Also Mapbender is still floating on the desktop.
>> that's ok, I expect(ed) some of those with all the new scripts. I'm
>> surprised there's just one to be honest.
>>> FYI looks like something is still making a /usr/local/livedvd-docs
>>> folder but all our stuff is in osgeolive-docs, someone want to find and
>>> kill that uneeded folder?
>> grep bin/* shows build_iso.sh, install_mapnik.sh, install_mapserver.sh,
>>  and main.sh still using it.
> Interesting, something to poke at when theres a spare moment, but it's
> only for consistency.
>>> Firefox homepage reset doesn't work, but that's nothing new,
>>> I did it by hand this time.
>> we'd have to find and attack the skeleton file, as the ~user/.mozilla/
>> dir doesn't exist yet when we run the install scripts. also it might pay
>> to investigate the ubuntu-theme firefox package and see how it does it,
>> and if it will override whatever we do.
> Actually it does, I always open firefox and go to the wiki to grab the
> commands I need, so under this circumstance it might work.
>> it looks like the ubufox package is putting the homepage in
>> /etc/xul-ext/ubufox.js
>> let's try editing it there.
>>> I also added the Geospatial menu from it's file, the cpu
>>> monitor and the keyboard switcher so I don't forget to do it on the
>>> final builds.
>> If you run the install scripts while not logged into the user account
>> running Xfce, that should happen automatically. (changes to disk get
>> blasted upon logout as it saves current state) I suggest to try running
>>  the install scripts from a xterm session or maybe install a tiny WM
>> like fluxbox to run the install scripts from?
> Well the problem there is a few of the things rely on being logged in
> (setting the background). I could try to make sure to uncheck the save
> session next time I build and see what happens. Personally I also
> cheatsheet the commands(to make sure I get them right) I need from the
> wiki but I can easily prep a text file to copy/paste from in a xterm.
>> no time to peek at the build logs right now, but asap.
>> thanks, Hamish
> 7z will be up in 10 minutes
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
