[Live-demo] directory structure ready to go
Jorge Gaspar Sanz Salinas jsanz at osgeo.org
Fri Sep 10 08:04:16 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
El 10/09/10 00:38, Jody Garnett escribió:
> Cool; I see the directory structure is ready to go...
> - https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/en
> Looks good to me; although I am a bit confused as I think that some of the different languages will need different themes (both the navigation and the OSGeo Live title can be translated).
> Jody
I don't know if you're planning to use some translation tool, but I
translated the geonetwork user documentation into Spanish using
OmegaT[1] and it worked like a charm (but I can't assure it will work
with reStructured Text markup because of the spaces).
The thing is that this tool works in a very different way than maybe
you've thinking on, because you feed it with your documents and it
creates a "translation memory" that you fill sentence by sentence. Thi
is the only "artifact" that should be versioned and you can "recreate"
the output directories (the "jp", "it", ...) with that translation memory.
The cool thing about that workflow is that when the original document is
changed or updated the software points you to the new sentences you have
to translate and then you can "recreate" the ouput directories so the
maintenance of the translation is easier than having to look the svn
differences to update all the translated documents.
I'm very sorry not to be a the code sprint today to share all these
ideas but, well, I had to return to Valencia yesterday :-/
I'll try to start translating liveDVD into Spanish but after FOSS4G my
spare-time-credit-for-geekery is low at this moment.
Cheers
[1] http://www.omegat.org/
Ingeniero en Geodesia y Cartografía
http://es.osgeo.org
http://jorgesanz.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJMih6/AAoJEAOYD75lvHdBe8gIAMUiI36VxOTr1RGE3DA1cB9S
dFkJ8gR6VrMw8Lu0GZz9FRHGWEtdywXnikj2qJ40nVKOZHc38y8fl5IoSeJH+Okd
Khny3ByFZTXoatLTi4uw9Q8dyte9y5a1vv/p3rckk1Vg2ejIUuvWhGFNKygNY2yY
cVsc0EzD9UEG6u43SjhguEhtCrop/4t5TWbK01s+2lhIOS5pKQN6/Yy3EJt6iUtB
27is2czh2XCtaYRgRXHluh5hErU9dDvPJND9MPrQElImTT30WbdjMysONItabIzQ
SlhgJYYXYMISDsk7VgBkEAD4VTEK2DV7QxrSGbZF/W2OYWcb1/dL06NEUK9GAY8=
=ISUZ
-----END PGP SIGNATURE-----
More information about the Live-demo mailing list
